Formula oro k18 bra...
[Closed] Formula oro k18 brakes with Hope floating rotors, do they work together ?
3 Users
Thinking of changing my Formula rotors to Hope floating, I'm currently running 180F & 160R.
Also is it rue using spacer between the caliper and mount makes possible to run Hope 183mm rotors.
Any tips or experience welcomed
Posted : 30/03/2012 8:57 am
 grum
I use hope floating rotors with my formula the ones. There was a very small amounts of rubbing from the raised bits on the rotors fouling the caliper, but it seems to have stopped now (I guess it's worn a small amount off the caliper, I read you could file it down but never bothered).
Posted : 30/03/2012 9:06 am
thanks grum
Posted : 30/03/2012 9:12 am
V2 floating rotors are fine, as they have a deeper braking surface, but only come in 180/203, mini/m4 rotors foul the caliper unless you file a bit off..
Posted : 30/03/2012 11:11 am
