Formula Oro Bleed I...
[Closed] Formula Oro Bleed Instructions
4 Users
Does anyone have the bleed procedure for Formula Oro brakes they can email me, or link to?
The formula site has a link but as far as I can see it's not the same as I have seen before, no bleed instructions there?
Also I believe they say DOT4 but I am sure Toby at Propel told me 5.1 was also ok, can anyone confirm or deny?
Cheers.
Posted : 23/11/2010 11:01 pm
Or is it the same as the R1, Mega, The One etc?
They have that procedure...?
Posted : 23/11/2010 11:04 pm
Its always when you ask that you then find it, the US Formula site has a good set of instructions, still interested in DOT 4 versus DOT 5.1?
Posted : 23/11/2010 11:11 pm
Doesn't matter, dot 4 is up to the task, dot 5.1 is more expensive but not so much that it'll ruin your day so buy the one you like the colour of.
Posted : 23/11/2010 11:14 pm
Be careful not to lose the smallest oring I have ever seen when you undo the bleed screw or they will leak.
Posted : 23/11/2010 11:16 pm
Thanks Northwind...
And yes, Mr Plow, I made that mistake the first time, the o-ring came out (i didn't see it) and wondered why the thing leaked until I saw it on the floor, and yes it is very very very small!!
Cheers guys.
Posted : 23/11/2010 11:22 pm
[url= http://www.singletrackworld.com/forum/topic/bleeding-brakes-how-to-an-idiots-guide ]Mr Nutt [/url]is your friend here. Follow this guide and all will be well.
+1 to the above, that O ring is tiny! and I'd want a mate to help too, there always seems to be a third hand needed.
I'd deffo go for DOT 4, it's less hygroscopic so takes on less water and is more stable. 5 is better at V high temperatures, Alps descent sort of thing, I never bother for UK riding.
APF
Posted : 24/11/2010 10:59 am
