formula brake pads ...
[Closed] formula brake pads ..where from ?
20 Users
 snap
Hi
currently getting through them very quickly
Wheres the best place/make to buy
also im running sintered at the moment ,is this the best choice for his time of year
Thanks
Posted : 12/02/2013 9:22 pm
Funny you should post this today. I recently had to replace my pads to my Formula RX brakes. I hadnt had the bike for too long, less than 6 months. Im not sure if that is to be expected but it certainly seemed a lot faster than the pads i had on my old bike.
Anyway, I had difficulty locating pads from local shops but managed to get them from Evans Cycles who had a fair range of them. At the time i bought the cheapest ones but today whilst cleaning the bike found that they have worn down to almost nothing already. So i'm going back tomorrow for more pads - probably more expensive ones this time.
I also find that my brakes are squealing like a banshee and that one side of the pad is wearing more than the other. Think i'll have to investigate why this may be...?
Posted : 12/02/2013 9:47 pm
Hiya - I run K24 Oro's on my bikes and always use sintered pads all year. Riding in the UK where it's usually gritty, muddy, sandy stuff I find they work best and last longest. Regarding makes i'm a bit of a brake pad floosie - I just buy whatever is cheapest 😳
I've tried all the brands from cheap to the most expensive over the years and I can't honestly tell any difference with how long they last. Superstar sintered pads are good, but i've also bought the EBC (?) pads in multi-packs off fleabay before and they also do the job very well!
Hope that helps!
http://www.discobrakes.com/?s=0&t=0&c=5&
Posted : 12/02/2013 9:50 pm
I use Superstar... Disco sintered didn't last as well or stop as well when I tried those.
Sintered is hard so will usually last better in winter... I use kevlar all year round but then we don't have particularily gritty mud.
OTOH I did discover while racing up north that if you do strike abrasive mud, the Superstar pad backing seems to be a very effective braking surface and my brakes still worked better than most people's at the end of the day 😉 Very nearly got to test the pistons.
Posted : 12/02/2013 9:53 pm
You need Swiss stop, I use them on my r1s.
Posted : 12/02/2013 9:55 pm
 grum
SS Kevlar normally but on a very very wet and muddy ride in Hebden they wore right down to nothing from nearly new.
Posted : 12/02/2013 9:56 pm
I use superstar sintered in my K18 & K24 Oros. Just worn out the ones on my hardtail after about 10 month of mainly muddy riding.
Ordered 4 new pairs last night funnily enough.
Posted : 12/02/2013 9:58 pm
ive just ordered two sets of sintered for my RX's this evening coincidentally. £14 delivered
these will typically last me 6 - 8 months of heavy riding, two finger stoppies even in the wet, great pads IMO
Posted : 12/02/2013 10:11 pm
I always use Alligator pads and find they stop well and have a decent life span in gritty conditions:
http://www.xcracer.com/shop/viewproduct.php?productid=219
Posted : 12/02/2013 10:31 pm
I use Uberbikes sintered pads in my RX's. Very happy with them, and seem to be lasting well.
Posted : 12/02/2013 11:10 pm
Another vote for Superstar sintered. Use them in my K18s and they last a decent amount of time and provide a pretty decent amount of stopping power as long as they're not filthy.
Posted : 12/02/2013 11:42 pm
Currently using alligator kevlar ones I think. They were fine until yesterday when they were rubbish and I was gnarling it up like a gnarly thing with no rear brakes
(That may or may not be true)
Posted : 13/02/2013 8:07 am
Anyone know where to get replacement pads for the RO? Just tried looking on the usual suspects and can't find them anywhere!
Posted : 13/02/2013 8:55 am
i use Clarke Organic,Sintered Uberbike,all very good..
Posted : 13/02/2013 9:09 am
Superstar kevlar, cheap and work well/last ages. Use them on K18's and RX's
Posted : 13/02/2013 9:27 am
R0 uses the same pad as R1, Th1 and RX etc.
Posted : 13/02/2013 9:36 am
Uberbikes here too. Lasting really well with plenty of bite and power. Great service too.
Posted : 13/02/2013 9:41 am
You sure? The RO has the oval pistons and the R1 doesn't....kind of thought the whole point in that was that you got a bigger surface area and more pad contact? Seems a bit daft to ovalise pistons and run the same pads (since you'll be getting less force for the same lever throw).
Posted : 13/02/2013 11:55 am
I'm using Superstar sintered. Seem to last well and no quality issues (e.g. pads dropping off backing plates) but they are quite noisy. I think all sintered would be similar. May try Kevlar next time.
Posted : 13/02/2013 12:02 pm
+1 for Superstar sintered (Formula RX)
Posted : 13/02/2013 12:10 pm
Yes I'm sure,[url= http://www.formula-italy.com/en/support-downloads ]Check out the exploded diagrams of each brake to see what the oval piston means and that the brake pads are the same across the range[/url]
Posted : 13/02/2013 12:47 pm
 snap
Hi
Many thanks for all replies , ive gone for superstar sintered ,going to give them a try
Posted : 13/02/2013 8:37 pm
