Forks upside down o...
[Closed] Forks upside down over night question.
5 Users
It's been about 7 weeks since I was out on the bike, but will be heading out for a ride tomorrow a.m.
Just had a quick look over it and see that the forks feel a bit 'sticky' and look dry around the seals.
Will it help if I leave them upside down over night?! And in the absence of any proper fork juice stuff, is there owt else I can work in there?
(Fox 36 with FIT - if memory serves me!)
Thanks!
Posted : 14/10/2011 7:10 pm
I have 36 talas, a few weeks ago they started grinding a bit and not sounding good, put them upside down overnight and they were good again the next morning. I must get into the habit of storing them upside down regularly, hardly ever do it.
Posted : 14/10/2011 7:19 pm
any decent lube will help - finish line green often reccomended. Coincidentally, I wandered through my garage half an hour ago, thought that I hadn't ridden the FS bike for a few weeks (Fox 32's) so gave them a wee squirt with Fork Juice and a gentle up and down.
Posted : 14/10/2011 7:22 pm
Thanks. I'll turn the bike over then!
Just read on another thread about Reverbs not liking upside down overnight.... anyone else experienced this?
Cheers!
Posted : 14/10/2011 7:25 pm
I have been doing this http://www.tftunedshox.com/cleaningyoursuspension.aspx
when I can be arsed after rides, seems to work really well. A little bit of oil (I just use chain lube) seems to go a long way to making them smoother for the next ride. If you try it tonight, leaving a bit of oil to seep down through the seal it may work for tomorrow
Posted : 14/10/2011 7:39 pm
except the clue is in the word 'seal'
Yes, storing them upside down will help, as will pulling the seal back with your finger nail and dribbling a little oil down there. Probably should be proper fork oil, but I always used whatever was to hand, (except WD40 or GT85).
Actually, on Fox forks, can't you prise the seal out without removing the lowers and lube the wipers properly?
Posted : 14/10/2011 7:47 pm
