Forks and Hubs
[Closed] Forks and Hubs
7 Users
Hi, So I have an old 20mm Pro2 hub currently laced to a 26" rim sat doing nothing.
I'm thinking of upgrading the front of my 29er from it's current QR set-up to bolt through forks by lacing the 29er rim to this hub.
As I understand it 20mm is 110mm wide. Does that mean if I changed the endcaps to 15mm I would need a boost fork or can I just get a normal non-boost fork?
Posted : 16/03/2020 11:15 am
Yes, if you have Boost/110mm hub you would need a Boost/110mm fork irrespective of the end caps
Posted : 16/03/2020 12:50 pm
Pro2 is 100mm with QR or 15mm, and 110mm with 20mm end caps.
Change to 15mm end caps and use non-Boost fork, or get the Boost adaptor and run Boost forks.
Posted : 16/03/2020 12:54 pm
If you fit 15mm end caps it’ll need a non-Boost fork as it’s not a Boost hub shell.
Unless Hope make Boost conversion end caps in which case you’d have both options.
They do
Posted : 16/03/2020 12:56 pm
If you're gonna be doing a new wheel build for 29in boost, I'd start with a proper boost hub myself.
Front hubs are much of a muchness anyway.
Posted : 16/03/2020 12:59 pm
What cha****ng said unless money is very tight. If you are determined to reuse the hub then Hope do a boost kit which requires a re dish. Since your rebuilding the wheel that's not an issue. Front hubs are cheap though so better to flog the wheel and just get a boost hub.
Posted : 16/03/2020 1:16 pm
Thanks guys - Happy to have a non-boost fork so i'll get some standard 15mm caps
Posted : 16/03/2020 1:18 pm
It’s not as easy as you might think to get new non boost forks, not at the shiny end anyway. Worth considering for the future.
Posted : 16/03/2020 4:49 pm
