Fork: What are the ...
[Closed] Fork: What are the symptons of worn bushes?
6 Users
 Earl
As above
Posted : 20/07/2009 9:48 pm
Knocking feeling through the bars,(simelar to a loose headset)
Turn the bike upside down,there should be no free play in the lower stanctions
Posted : 20/07/2009 9:53 pm
 Earl
When you mean free play - your talking about vertical free play?
If my bike is upside down and I punch the wheel down I get a knocking sound.
Posted : 20/07/2009 10:06 pm
Being able to see into next door's garden.?
Posted : 20/07/2009 10:47 pm
1. Play in the bushings. Forwards and backwards direction. Can been seen if you rock the bike and look at the seal. Can also be felt by putting you finger ontop of the seal between the stantion and arch.
2. Sticky fork action. If the fork has alot of initial stiction or feels notcy.
3. Stantion wear. The stantions start to faid as the surface is rubbed off.
Posted : 21/07/2009 7:09 am
Farting noise when you pull out.
Posted : 21/07/2009 7:17 am
If you're getting knocking with vertical movement of the fork its likely to be something to do with the damping?
Posted : 21/07/2009 8:01 am
 Earl
No movement back and forth and stantions are good - must be a damping cartridge prob then. bugger.
Posted : 21/07/2009 9:34 am
Perhaps a service is required. When were they last done?
Posted : 21/07/2009 10:43 am
 Earl
2 years ago but haven't done much riding on them since so seals are still good. Thought they may have missed the bushes - hence the question here.
I did change the travel from 125mm to 100mm myself so could have messed something up.
Just rung Mojo. They won't do any work on a fork unless atleast a full service is undertaken. Can't save any pennies here then.
Posted : 21/07/2009 7:02 pm
