Fork Swap Advice
[Closed] Fork Swap Advice
4 Users
I've got a 2020 Trek Rail with 160mm Yari 29er forks running a 2.6 tyre and I've spotted a set of 2019 180mm Lyrik forks for sale from a Kenevo Expert. As best I can see, the differences are 42mm offset on the Yari and 46mm on the Lyriks. The axle to crown is 572 to 576. The Kenevo runs a 27.5 wheel with a 2.8" tyre so I would expect it to be a 29er fork but it's marked as 27.5.
The steerers are the same length.
Assuming my 29er wheel fits, can anyone foresee any issues?
Posted : 02/06/2020 4:35 pm
I wouldn’t have thought a reasonable size 29’’ tyre would fit.
I tried a 29 2.35 magic Mary with my boost 27.5 Lyrik and it was no where near so there’s no chance with a 2.6.
Posted : 03/06/2020 6:53 am
Depending on cost you could stick in a 180mm debonair air spring (£42 last time I looked) and a charger damper to your Yari and you’ve basically got a Lyrik.
Posted : 03/06/2020 6:55 am
@joebristol sure, but that'll cost more than the Lyriks and I'll have the Yaris to sell to offset the cost as well.
@simonhuscroft that's my main concern too.
Posted : 03/06/2020 7:20 am
20mm more travel but only 4mm more in crown to axle height.
Ask yourself where the other 16mm have gone.
Posted : 03/06/2020 7:23 am
If it makes sense cost wise You could
possibly buy the Lyrik and swap the damper then sell the Lyrik on as a 180mm Yari.
Would depend if you think it would be worth the hassle and possible / if any cost savings.
There’s no way your 29 will fit in the 27.5 Lyrik though.
Posted : 03/06/2020 8:12 am
