Fork lower question...
[Closed] Fork lower questions??
5 Users
Hi lads when you remove your lowers and put them back on do you compress them fully and tighten the foot nuts to effectively form negative pressure in the lowers?
I have never done this but some YouTube videos show this. I've been having a debate with my mate and I said it is wrong he says that it's right.
I've never had a problem with leaving them extended.
Who's correct? 🙂
Posted : 25/12/2018 9:02 pm
No. Forks either have a valve for manually adding negative pressure or they self balance between the positive and negative chambers.
Posted : 25/12/2018 9:42 pm
Hi mate thanks for reply but I don’t mean in the air shaft. I mean the lowers of the fork where the stanchions go in. The dust seals do a good job of sealing the lowers so air either gets trapped in or a vacuum.
Posted : 25/12/2018 10:00 pm
Your right.you want to extend the forks
Posted : 25/12/2018 10:08 pm
Extended, if you re-assemble whilst compressed and then inflate you create a vacuum in the lowers, not what you want (acts like a secondary negative).
Posted : 26/12/2018 2:12 pm
Hey Dazzzzbo. About a year ago I was wondering the same thing. I’d seen the you tube vids that showed the lowers comressed, so it created more negative pressure (or something like that). I tried it and it didnt work wel. exactly as dirty dog says above.
When watching the proper SRAM , xfusion and fox “how to” videos, they always do it uncompressed. I get the concept of doing it compressed, but it’s not how the manufacturers rcomdn(and they should know).
Posted : 26/12/2018 2:18 pm
