Fork help please
[Closed] Fork help please
3 Users
I am in the middle of servicing my recon gold tk fork, i am at the reassembly phase and as per RS website i am trying to put 133ml of 5w in the damper side upper tube, however the leg starts to over flow at around 120ml am i missing something here
Posted : 21/11/2013 9:53 pm
you have lifted the stantions to their upper position before putting the damping fluid in?
Posted : 21/11/2013 9:59 pm
The lowers are still removed and the damping rod is fully extended
Did you measure the fluid you took out.?
Posted : 21/11/2013 10:04 pm
No unfortunately as i thought the manual would be acurate, its baffling me
Posted : 21/11/2013 10:06 pm
Shaft stuck.Chuck the lowers on.Pump them up to about 140 psi then try.
Posted : 21/11/2013 10:31 pm
That seemed to do the trick, thanks for the tip
Posted : 22/11/2013 12:15 am
Good here init... 😉
Posted : 22/11/2013 12:20 am
