Fork help
[Closed] Fork help
4 Users
I have never been proper off road biking before. When I was growing up my friends were always trying to get me into it, but for one reason or another I never did try. Something recently has got me interested and I'm building a bike based on a Kinesis Maxlight XC2.
I was originally planning to build a tourer, but realised I have overspecced the components and have decided to make it dual purpose trail/touring. Unfortunately I have bought combined shifters / brakes ST-M760's which are mechanical, and a nice set of xt v-brakes. I also have a set of wheels that aren't disc compatible.
So here is my question. Should I get some BB7's or similar and go disc, meaning new wheels too (not really a big deal), so that I can get some disc forks, or are there forks out there somewhere that will fit my requirements?
The frame needs 85-130mm travel, and has a 1 1/8" steerer.
Help!
Posted : 02/08/2012 10:57 pm
depends how deep you pockets are. if money dont matter, disc is better 99% of the time off road. and there are plenty of forks out there to suit.
Posted : 02/08/2012 11:01 pm
If your able to return the brakes and wheels then definatly look for disc setup. Avid bb7 are good mechanicals..
Posted : 03/08/2012 12:45 am
It seems a waste not to use those component but your obvious issue is locating forks with v-brake mounts. New this is a big issue due to the lack of forks with the mounts, though hopefully some-one else may have some suggestions, or go 2nd hand. Also I'd suggest maybe a fork in the middle of your travel range with a lockout (for tours duties) would be the easiest solution. Maybe an older set of Rockshox Reba's (pre 2010?) and budget for a good service.
That's not to say I'd choose v-brakes over disc, but in your situation, unless you have money to burn or can return the parts, it will be the most economic solution.
Posted : 03/08/2012 10:56 am
