Any one know where there's a guide for this to what psi you put in, I bottomed them out a couple times the other day. Off a 2013 orange five pro
Guides don't work. Just set sag at 20-25%
Sounds normal for 2013 CTD.
If upping the pressure doesn't work you may be able to get around the issue by adding extra float fluid to the top of air piston.
Don't Mojo offer a discounted upgrade to the 2014 damper for these, or did I just make that up?
How you do add extra float fluid? Depress the valve and wait whilst it drips in I guess. Just looking for confirmation.
Release pressure in left hand leg, undo six sided alloy fitting on top of leg, pour in 5 - 10 ml fox float fluid reassemble and inflate to suit ( I weigh 73 kg and have around 90 psi)
I'm 99kg and they now have 110psi in, got them spot on now
