I was choosing a new front disc but was mentioned that forks have a max size rotor they are rated to be able to use without any issues with flutter or twist.
I cant find this info anywhere for mine!
Fox Rhythm 34 Float, GRIP adjustable damper, E2 tapered steerer, G2 Geometry w/51 mm offset, Boost110, 130 mm travel
Tried looking at the FOX site but couldnt really find anything relevant!
I'm on 180mm (the forks have 160mm + adaptor), but was looking at 203mm, but don't want to get any negative effects!
I seem to recall the I noticed the Fox website states 180mm max on the Fox 34s that were supplied OEM on my Jeffsy. The bike was supplied, again OEM, with 200mm front rotor...
I wouldn't worry too much.
Try putting your serial number in here.
https://www.ridefox.com/fox17/help.php?m=bike&ref=findbyserial
Just checked the above and it says on FOX website:
Maximum brake rotor diameter for all FOX forks except Step Cast 27.5in is 203mm. Step Cast 27.5in forks have a maximum rotor diameter of 180mm.
That’s interesting what’s yours?
