Fork changing on a ...
[Closed] Fork changing on a 29er
4 Users
Hi
Bit of advice needed ... currently have a Zesty TR and want something more burly or possibly swap fork out to improve the front.
So, would changing the fork to a X Fusion trace 140mm mess up the geometry or would i be OK ? Think difference is around 20mm A2C.
Failing that, maybe a codiene 29 is the way forward ??
Thanks
Posted : 01/02/2016 5:26 pm
What fork do you have now?
Posted : 01/02/2016 5:45 pm
Its the standard RC rev
Posted : 01/02/2016 6:22 pm
Is the travel too much at 140mm for the Trace on your frame? If so you could adjust the travel internally I believe? I have them running at 120mm on mine.
Posted : 01/02/2016 6:46 pm
Pike is great at 120mm, got one on my 29er.
Zesty frame looks pretty solid but I never rode one, can you feel the rear end flexing or the chassis squirming under you then?
Posted : 01/02/2016 7:58 pm
I swapped the Fox 32 ctd 120mm fork fixed to my 29er for x-fusion trace and it made a hardly noticeable change to the geometry but the improvement in terms of stiffness and extra travel was huge.
Posted : 01/02/2016 9:42 pm
