Forgive my ignoranc...
[Closed] Forgive my ignorance
8 Users
What is boost?
Posted : 22/11/2018 9:18 am
Wider axle standard, wider hubs and spoke flange spacing. Don't know the sizes.
Intended to be a stronger wheel build for the now larger diameter rims.
Posted : 22/11/2018 9:21 am
Chocolate bar.
That and a chocolate bar advertised by Vic Reeves and the Wonder Stuff, I think.
Thanks Jef.
Posted : 22/11/2018 9:47 am
 qtip
Also changes chainline, hence Boost-specific cranksets.
Posted : 22/11/2018 9:50 am
So boost wheels will fit my 29r?
Posted : 22/11/2018 9:57 am
You'll need 29er specific boost for that.
Posted : 22/11/2018 9:58 am
It's a frame and hub standard. They need to match. Do you have a Boost frame?
Posted : 22/11/2018 9:59 am
Depends is it super boost or standard boost?
Posted : 22/11/2018 10:00 am
It's a Sonder Signal
Sonder sure says it's Boost 148( the most common option) so your rear wheel will need to be a Boost hub with a 12mm axle.
Posted : 22/11/2018 10:10 am
It's these I want to fit.
https://www.ubyk.co.uk/hope-tech-enduro-pro-4-evo-boost-29er-wheelset-custom/30752
Posted : 22/11/2018 10:24 am
 Yak
Here you go:
edit - cock, can't get the pic in.
Imagine a photo with all the hub sizes shown and the required over-locknut dimensions.
Posted : 22/11/2018 10:32 am
Those wheels from ubyk should be fine.
Posted : 22/11/2018 11:01 am
Cheers!
Posted : 22/11/2018 11:19 am
