Flying with a bike ...
Flying with a bike with sram t type derailluer
4 Users
2 Reactions
Has anyone flown with a bike that uses a type derailleur? If so what did you do with the derailuer?
On previous bikes that has regular derailleur attached to a hanger, I'd just unbolt the hanger to stop the bike frame from putting pressure on the derailuer and damaging it when the bike was in transit in a bike bag/box.
But with t type, unmounting and remounting the mech looks like it would involve going through the whole calibration/setup process again.
Is t type tough enough to leave bolted on the frame? Or is there something I'm missing here
Posted : 01/09/2024 6:26 pm
I just marked where the hanger was aligned using a Sharpie then took it off for the flight. Bolted back on in same place. That was that.
Posted : 01/09/2024 6:33 pm
mashr and mashr reacted
The setup process takes about 2 minutes…
Posted : 01/09/2024 10:11 pm
I took mine off for a flight. It was a bit of a pain to put back on correctly so watch a vid.  It does need 35Nm otherwise it slips but everything else is simple.  I assumed set up was super simple, it is but there are steps.
Correct gear, set up position, tight chain 35Nm. Done.
Posted : 02/09/2024 7:32 am
Thanks all - might try marking the position somehow to save the faff.
Posted : 02/09/2024 7:56 am
