Fluxient XM-L2 ligh...
[Closed] Fluxient XM-L2 light - a mini review
3 Users
It's p***ing down outside so I thought I'd start another LED light thread 😉
Just got myself one of the single LED Fluxient XM-L2 light kits from Bike Lights UK. £70 delivered with 4400mAh battery. Claimed output is 1000 lumens.
I wanted something with a decent log distance throw to compliment a twin U2 on the bars. I also wanted something reliable, with a decent battery and charger to use alongside the cheap chinese ones I've been messing about with.
As soon as it arrived it was obvious that this is a quality product.
Very nicely packaged:
Comes with fully waterproof 4400mAh battery pack, extension cable, charger, a couple of rubber attachment rings, head strap and even a little bag to store it all in:
Size comparison with old XML-T6 head unit:
Mounted and ready to go:
The first thing I did was connect it unto my meter and measure the current drain to get an idea of run time I can expect. It's pulling around 1.4 Amp on full, which is about 50% more than the single T6. It should be good for about 2 hours on my little 2 cell 3.2Ah homemade battery, or nearly 3 hours with the supplied pack.
The build quality is excellent - well finished with deep cooling fins on the body. Running it on full power indoors it gets warm, but not to the same extent as the T6 and nothing like the SS-X2. Powering down due to overheating shouldn't be a problem in normal use.
Out on the trail this thing throws out a serious amount of light for a single LED unit. It's definitely a mid to long throw spot - for looking down the trail to choose a line it's great. For fast descents where you're more concerned about what's in the mid distance rather then what's directly in front of your wheel it's great. For slower stuff you might need a bar mounted flood to fill in in the near distance with a bit more light.
I found I just left it on full most of the time and just switched on the X2 as needed, rather than the other way around.
This is advertised as being designed for fast road use, or as a compliment to a bar mounted light for MTB use, which I reckon is pretty accurate.
Definitely recommended, and definitely worth the price premium over the chinese stuff. If you're looking at getting one of the cheap chinese units and buying a decent quality battery and charger to go with it I'd say don't bother. Just get yourself one of these or the 4xR5 version instead.
I'll try and get some beam shots up at some point, but there are some on [url= http://www.torchythebatteryboy.com/p/bike-light-database.html ]Torchy's website.[/url]
Posted : 09/11/2013 2:31 pm
I have the U2 one and it's brilliant, its battery is currently powering my solarstorm and this is on the bars with another battery.
Posted : 09/11/2013 6:07 pm
Phil, seems an odd setup going by Mark's comment and the normal XML innate 'spottiness', surely the SSX2 would be better on the bars?
Mark, how do the T6 and Fluxient beams compare?
I'm more interested in the beam flood/focus comparison rather than overall power differences
Posted : 09/11/2013 6:12 pm
z1ppy - The T6 and Fluxient have very similar beam patterns. So much so that the T6 on high is indistinguishable from the Fluxient on mid power. There is a reasonable amount of light in front of the wheel if you aim the beam about 10-15ft in front of you, but nothing like a Solarstorm. It really works best on the helmet to light up the mid-far distance. This was how I had the T6 set up, and this does much the same job, but with more power.
I've had a chance to test the supplied battery properly, and it's good for a genuine 4.6Ah, so slightly better than the claimed 4.4Ah. (I've seen Torchy selling the batteries at £25 on ebay)
Posted : 09/11/2013 7:57 pm
