Flow 29er rims help...
[Closed] Flow 29er rims help!!!
11 Users
I tend to use this wheelset for commute and off road pursuits, so often i need to change the rubber. Any tips for getting the tyres on easier seems to be i need the strength of Thor. Is this normal because the design of the rim is meant to run tubless, Cheers.
Posted : 11/12/2014 2:25 pm
Are you pushing the tyre bead into the grove in the centre of the rim to give you a bit more slack to work with?
Posted : 11/12/2014 2:39 pm
Doing all that,even soap on the bead, dont have this trouble with my Mavic 819 or Hope Enduro rims. Puncture on the trails or commute dont bare thinking about , thanks for your reply.
Posted : 11/12/2014 3:01 pm
What tyres? My Flows are easier to get tyres onto than my 819s...
Posted : 11/12/2014 4:05 pm
I just put some new Halo Twin Rails on my Arch Ex rims - involved 2 people, a lot of swearing and a pinched tube puncture. I've added a load of sealant to the tubes as I really don't fancy a road side repair. Hopefully will get easier as the tyres get older.
It's all very well saying get the bead in the groove, but these are wired with a wide bead it's very difficult to get it to stay put while you wrestle with it.
Posted : 11/12/2014 4:14 pm
Ardents,Nobby nics,Wtb and On one Smorgasbords all an absolute bitch,use a lever and i tend to pinch the tube.
Posted : 11/12/2014 4:24 pm
Spesh fit (and go up tubeless) a treat on Flows. I'd have thought Smorgs should do too.
Posted : 11/12/2014 4:26 pm
Why would you use tubes on a flow rim?
Posted : 11/12/2014 4:27 pm
 devs
4 sets of flows here. Never used a lever. You must be doing something wrong.
Posted : 11/12/2014 4:36 pm
Tried fitting 2 Intense spikes to flow ex and found same issue.
Applied more liberally fairy liquid and eventually voila!
Posted : 11/12/2014 4:51 pm
Minion tubeless ready goes on with my Flow 29ers with thumbs easy.
Schwalbe super gravity Magic Mary's require huge persuasion and even a metal "tyre iron"
Spare cheap wheelset for commuting would help
Posted : 11/12/2014 6:03 pm
Simply this.
There is a bit of a knack to it but get the bead in the groove all the way round n it'll go.
Had a customer return this wheel saying the rim was faulty as 3 bike shops failed at getting the tyre on.
On receiving the wheel I filmed this below and emailed it him before refunding with a reduction due to the rims being chewed up by heavy duty tyre levers...
[URL= http://s430.photobucket.com/albums/qq24/edoclaura/Misc/?action=view&current=MOV_1661.mp4 ][IMG] http://i430.photobucket.com/albums/qq24/edoclaura/Misc/th_MOV_1661.mp4 [/IMG][/URL]
 br
You've already 3 sets of wheels, just buy another (cheaper) set for commuting.
Posted : 11/12/2014 6:06 pm
