flatbar shifter que...
[Closed] flatbar shifter question
3 Users
Will Shimano r440 9 speed triple shifters work with my current setup which is 9 speed 105 rear mech front mech is a triple tiagra .
Posted : 27/01/2015 10:44 pm
 ton
yes, all you stuff is road gear.
to be honest shimano mtb shifter work with the road stuff too.
Posted : 27/01/2015 10:46 pm
road mechs yes
ton, not quite...
9spd mtb RH shifters will work with road rear mechs
10spd mtb RH shifters won't - different pull
MTB LH shifters won't work with road front mechs as again they are different pul (although you can get round this if you're running a double front mech)
Posted : 27/01/2015 10:50 pm
 ton
my mind dont work in 10spd yet....... 😆
MTB LH shifters won't work with road front mechs (again, different pull)
yes they will. i put deore shifters on my son's charge plug, which is sora or tiagra.
Posted : 27/01/2015 10:51 pm
I just edited my first response. The cable pull is different but you can bodge it on a double.
Posted : 27/01/2015 10:55 pm
It looks like I will have to change front mech then or I might just run 1x9 as it is only for commuting .
Posted : 28/01/2015 6:25 pm
