Flat edged 24mm + 3...
[Closed] Flat edged 24mm + 30mm rockshox sockets or spanners
12 Users
Can anyone help me source decent flat sockets or well proved suitable spanners for servicing rockshox forks?
RS make the mission control spanner for a lot of money and there's a firm in the states making bespoke tools that once Duty has been added get kinda pricey too. Just wondering if there's anyone out there turning regular sockets down with a lathe or knows of a source for cheaper alternatives?
Posted : 24/09/2014 8:34 am
I've always just used a very large adjustable spanner and a bit of care.
the jaws sit on the nuts flat and don't dig in at all. If you get a reasonable one they don't separate or twist under the sort of torque a fork needs.
Posted : 24/09/2014 8:38 am
Park do a 24mm cone spanner which is ideal and IIRC about £7. (I got it so that I could take boxxer dampers out without having to remove the fiddly dials, but it's the same job essentially).
Posted : 24/09/2014 8:46 am
I bought a 24mm for my Maverick forks from eBay, there were loads to choose from mist <£10
Posted : 24/09/2014 8:47 am
Cool, so i just need one of these:
http://www.fatbirds.co.uk/2209/products/park-tool-scw24---shop-cone-wrench.aspx?origin=pla&kwd=&currency=GBP&gclid=CLrti-67-cACFfSWtAodnEYA_w
Great idea.
Posted : 24/09/2014 8:49 am
Loco sells em - doesnt he?
Posted : 24/09/2014 9:11 am
I have a spanner for taking shower fittings off its basically just a thin spanner aka cone spanner.
http://www.toolstation.com/shop/Compression+Fitting+Spanner/p62263
Its a bit on the short side and not the most ergonomic but if you're in a hurry it'll get the job done. Otherwise if you can wait a few days I'd go for the park cone spanner.
Posted : 24/09/2014 9:15 am
I've got a 24mm socket that fits a 1/4 inch drive ratchet that does just great. You can buy them in singles for less than a fiver. Old skool combination ring spanner and the ability to hold it on and work carefully will also remove them.
Posted : 24/09/2014 10:56 am
Scapegoat, and links to your 24mm sockets?
Posted : 24/09/2014 11:08 am
I just bought a 1/2" drive 24mm single hex socket and ground it flat with a hand file. Took a little bit of work but works perfectly.
Posted : 24/09/2014 11:50 am
Bench grinder and a normal 24 socket for me.
Posted : 24/09/2014 4:29 pm
I made an arbor from a coach bolt, spun the socket up on a cordless drill and flattened a 24mm socket on the bench grinder, worked a treat.
Posted : 24/09/2014 6:41 pm
Plumbing wrench off ebay for a couple of pounds
[img] https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcQYsffdaeu_8T1aVne20ovD1YWY-0j3-E4OY_xxkNFl6WDsD0fN [/img]
Posted : 24/09/2014 9:58 pm
