Does anyone else find flash photography on the Galaxy S2 to be incredibly dark? It seems like there is a bit of a delay between the flash and shutter firing, resulting in an under exposed shot. I've messed around with the scene modes etc, and it seems that disabling the flash improves the situation, but I can't imagine that's expected behaviour. Bonkers!
It works fine for me.
One thing I have noticed is that the flash itself isn't very powerful, so the drop off after only a few meters is pretty bad.
Also, you could try upping the exposer control from the settings menu to see if that helps?
thanks Dan1980. I've tried that, unfortunately it seems to make little or no difference 🙁
