Fixing Shimano shif...
[Closed] Fixing Shimano shifter?
4 Users
Hello, my right shifter (Shimano Deore) has stopped returning after being pressed.. seems like a spring has snapped inside. The shifter still works but I have to manually pull the lever back into position for each gear change. Is there any hope of fixing this? If not.. anyone have a good 9 speed shifter for sale?!
Dan
Posted : 01/02/2013 12:17 pm
Before you take anything apart, check that the brake lever's not pressing against the shifter body, as this can cause the levers to stick.
Posted : 01/02/2013 7:09 pm
Does the cable need cleaning or replacing?
Posted : 01/02/2013 7:15 pm
If its getting old they often get gummed up inside
It can be as easy as squirting in loads of wd40 etc
Or take the cover off and have a look inside its not very often that they fail or somthing snaps
Posted : 01/02/2013 7:17 pm
