fixing cut tyres
[Closed] fixing cut tyres
9 Users
managed to get a 1/2 inch cut in my road tyres, the tyre is practically brand new so is there anyway of fixing it or best just to buy a new one
Posted : 14/06/2012 10:36 am
I have used superglue in the past ( worked quite well),but never on a cut that big.
Posted : 14/06/2012 10:39 am
That size and on a road tyre, just bin it. Smaller and on an off road tyres, I'd suggest a car repair plug patch.
Posted : 14/06/2012 11:07 am
I've used super glue and a inner tube patch on the inside of the tyre on my road tyres successfully, but only for much smaller cuts.
At 1/2", I would chuck it.
Posted : 14/06/2012 11:11 am
Bin! Even if you do manage to repair it, likelyhood is at somepoint it'll ruin your ride again!
Posted : 14/06/2012 11:22 am
if you do manage to fix it, i'd strongly consider only running it on the back.... front tyre blowout at speed is not fun; back also not great, but vastly preferable!
Dave
Posted : 14/06/2012 11:30 am
sew it with dental floss, patch on the inside
Posted : 14/06/2012 11:35 am
Does the dental floss thing work? I've got a small pile of ripped tyres that I've never brought myself to throw out, keep meaning to try! Some with fairly big holes.
Posted : 14/06/2012 11:37 am
The floss thing will work with some patching on the inside too, but best as a get you home fix, some will run them normally
I'd never consider trying to repair a road tyre because of the 100psi they run at, bit different on an mtb tyre with only 25-35psi
Posted : 14/06/2012 11:39 am
You honestly want to fix a tyre that is less than 25 mm wide, pumped to 125psi and which you ride at upto say 45mph.
Brave man!!!
Bin it!
