Fixing corroded dow...
[Closed] Fixing corroded downtube gear cable stop?
4 Users
I've got an aluminium frame where the downtube cable stop for the front mech has gone and corroded - when I tried to remove it, I just ended up snapping off the outer part of the threaded steel insert.
So now I've got the remains of the steel threaded insert nicely stuck inside the aluminium "braze-on" (or whatever it's called).
Any suggestions for fixing this?
Thanks
Posted : 17/07/2018 9:24 pm
https://www.sjscycles.co.uk/search/?term=cable%20stop
One of these jobbies?
Posted : 17/07/2018 9:27 pm
I tried some GT85 yesterday, and today my easy out just got wedged in and only just came out, leaving the rod behind 🙁
Posted : 17/07/2018 9:43 pm
Depends on access, can you get a drill straight on it or does the head tube push the drill squint?
Posted : 17/07/2018 10:04 pm
Heatube makes it a bit wonky. Might get in with a flexible end.
Are you thinking drill it out, then helicoil it?
Posted : 17/07/2018 10:17 pm
I have drilled them out until you can pick out the thread, needs to be dead straight though. Then chase with a tap.
Posted : 17/07/2018 10:57 pm
Could you get a small screw in from the other side? Might be enough to get it moving?
Posted : 17/07/2018 11:05 pm
Removing bolts etc. that are so seized that they've snapped is not a job that easy-outs are designed for (no matter what the salesman has told you). It's not going to come out without a lot of aggro, even if you could get straight access to it, so why not cut your losses and fit an inline adjuster instead?
Posted : 18/07/2018 6:29 am
