Fixing a broken por...
[Closed] Fixing a broken portable washer
6 Users
Hello. My portable brand x washer has broken. It makes a kind of groaning noise but doesn't suck up any water. Is it a gonner or has anyone successfully managed to fix these things? It's one that just plugs straight in to the car rather than battery powered but thought about making a separate battery pack, anyone done this?
Posted : 13/07/2016 9:27 am
I have a mobiwash that did something similar. Started blowing fuses.
I stripped it down and found a bearing on the pump almost seized. Cleaned it it, greased it and its now working again.
Insides arent complicated, get your screwdrivers out 🙂
Posted : 13/07/2016 9:46 am
Ok will do some routing around the insides
Posted : 13/07/2016 12:01 pm
Better off rooting about the insides otherwise you'll end up with lots of plastic swarf clogging your pump.
Posted : 13/07/2016 12:09 pm
With regards to a separate battery pack - I have a jump pack I keep in the car which has a cigarette lighter style plug socket so run the washer off of this, especially if washing multiple bikes. I figure it is cheaper to recharge the pack at home than to run the car while using the washer, plus you can move to the best location for washing
Posted : 13/07/2016 12:36 pm
Puddings, excellent idea! Which pack did you use? Does it give the washer enough beans to work same as off a car?
Posted : 13/07/2016 12:38 pm
I use a slightly more powerful one due to having a somewhat arsey disco that needs a bit of welly to start in the cold if it hasn't been run for a few days (despite new battery). I haven't seen any power drop off although to be honest the mobi washer is not super powerful - if you have a high powered unit it might be a different story
I have the jump start 4000 from clarks (machinemart own brand)
[url= https://www.machinemart.co.uk/p/jump-start-4000/?da=1&TC=GS-010311030&gclid=Cj0KEQjwzZe8BRDguN3cmOr4_dgBEiQAijjVFsoZHlafsw6YhmUeMXANikHf3XtpnWy6h5T0KEtrlyAaAuHv8P8HAQ ]
Posted : 13/07/2016 7:32 pm
Was probably looking at something sub £60?
Posted : 13/07/2016 9:21 pm
i use a jump pack. Works fine
Posted : 13/07/2016 10:05 pm
Unless your car has got a real pee-wee battery, can't you just use the washer from the car with the ignition off?
I used to regularly use my Dirtworker to clean two bikes after a ride without the ignition on & never had any issues with the car failing to start.
I think diesels have larger batteries than petrols as they are harder to start, so perhaps that was why it was never an issue, although I suspect you'd drain the water tank on the dirtworker long before you got anywhere near draining a car battery.
Posted : 14/07/2016 7:43 am
Yes most of the time will just run off the car but at races its often handy to have the option of self power. Plus I want to use it in my shed as well so dual purpose.
Posted : 14/07/2016 9:45 am
wenanwhere - Member
Ah. Good for the shed & other situations when you are away from power.
The only time I used mine away from the car, I used a camping power adaptor with cigaretter lighter socket (for camping fridge) so still had to be in range of a power cable.
Posted : 14/07/2016 9:53 am
