Fitting suspension ...
[Closed] Fitting suspension forks to my Singular Swift (questions)
8 Users
Hi,
Just got a Surly Ogre so I'm sorted for a steel rigid frameset. Don't really want to sell my Swift so thinking of putting suspension forks on the front to make it a bit comfier (can't get much fatter tyres on there) and more suitable (than the Ogre) for a fairly bumpy ride I often take near my new house.
My question is what a2c fork do I need?
Swift forks are 470mm. Should I just get a sus fork with the same a2c? Or does fork travel come into it?
Also I need a straight steerer (pretty long too) which is a pain in the bum. Looking at some second hand options or the Manitou Markhor but that comes in 3 different a2cs: 490, 510, 530. Which do I get?
I appreciate this is the cheaper end of the market but hoping it'd be a bit better than the plethora of heavy cheap Suntour or Chinese fork options.
Also been offered a x-fusion rl2 but don't yet know the a2c. Also I suspect the steerer is a bit short. And it needs servicing.
Apologies I'm fairly clueless about suspension, all but one of my bikes have been rigid.
I've also been looking at building a fat front end. Can find forks pretty cheap but the rim and tyre cost is putting me off. Especially as I think it'll look a bit rubbish. But the lack of maintenance is a major plus to me.
Posted : 07/06/2019 12:29 pm
Same A2C roughly, but forks will sag (compress) when you sit on them, typically about 25-30% of their travel, so that A2C measurement will shorten a bit.
I'd say somewhere around 500 A2C for an 80-100mm travel fork will suit you.
This RockShox Reba 29, for example, is 506mm A2C which is in the right ballpark - 25% sag of 100mm travel would bring that down to 481mm, 30% to 476.
https://www.bike-components.de/en/RockShox/Reba-RL-Solo-Air-Boost-29-Suspension-Fork-2019-Model-p63644/
Posted : 07/06/2019 12:37 pm
 PJay
There's some info. on the [url= http://www.singularcycles.com/faq/ ]Singular Cycles FAQ page[/url] and it looks like you'll be after an 80mm or 100mm fork (if you can find one with a straight steerer) but why not drop Sam an email (recently I've been getting replies in 5-10 minutes!)?
Posted : 07/06/2019 12:39 pm
Thanks guys.
I'll drop Sam and email.
Posted : 07/06/2019 12:51 pm
Although now I really want to build the fat front end. No matter how bad it looks.
Posted : 07/06/2019 1:07 pm
If you do want a fat front end I have a salsa enabler fork ( straight steerer ) with a fat wheel + tyre ( surly large marge rim with cutouts ( original factory special i think ..not DIY ) . Possibly a choice of 4" tyres. Been saving for a project but may sell if the price is right ! You can PM me if interested. Funnily enough I have an Ogre too and did have a swift. Just love steel 29ers rigid with a fat front end , the lack of dive + comfort and the simplicity .OK fast bumpy stuff shakes you about but I'm a bimbler/explorer these days and actually prefer the climbs!
mail in profile.
cheers
Bill in exeter
Posted : 07/06/2019 3:34 pm
BTW ..I fitted a RS Reba to the Ogre and soon took it off ..much preferred rigid . The original fork was far to stiff IME . I swopped it for an exotic carbon + fatter tyre which worked much better comfort wise . Due to advancing years comfort is a priority these days !
Posted : 07/06/2019 3:42 pm
I fitted suspension fork to a Swift, but prefered it rigid.
Posted : 07/06/2019 3:54 pm
Thanks Bill, I suspect that'll be too expensive for me though.
Current plan is this fork:
https://www.cnc-bike.de/product_info.php?cPath=50_44_1170&products_id=14534
and then a wheel as cheap as possible.
Posted : 07/06/2019 4:13 pm
that fork looks interesting and a very good price! wonder what the offset is as few details?
Posted : 07/06/2019 9:00 pm
Def leave the std steel in place, the frame was designed that way and works perfectly.
It will still take quite a large volume tyre up front.
If it is fat you want, why not put a puffin fork in there ?
Posted : 08/06/2019 6:46 am
Skankin-giant
Same here. Bought an expensive fork. Had it on for a week, and took it off, never to be refitted.
I suggest trying to borrow a fork first to make sure you like it.
Posted : 08/06/2019 8:14 am
I've just bought an on-one fatty fork very cheaply. Has the same a2c as the puffin fork. I'll try that.
Thanks.
Posted : 12/06/2019 7:57 pm
I’ve had a Krampus cork and 29+ wheel/tyre on my Swift for two or three years now. It gets used almost exclusively for bikepacking and I love it.
Posted : 13/06/2019 8:04 am
