Fitting mudguards t...
[Closed] Fitting mudguards to my CX (Planet X XLA)
3 Users
Hey,
I have just done my first club ride with the local club (I was the only one on a CX but it seemed to keep up OK).
I think they will probably require mudguards in the winter.
What guards do I need and how on earth do I fit them?
Cheers,
Mick
Posted : 03/09/2019 10:22 am
I'm just wondering if the Axoim Roadrunners will fit?
https://www.axiomgear.com/products/fenders/full-coverage-fenders/roadrunner-ar-road/
Posted : 18/09/2019 10:05 am
 nbt
Bit of bending required on front stays, but any mudguards will fit. I use SKS Bluemel Reflective Mudguards
XLA with guards fitted
Posted : 18/09/2019 10:31 am
They look good. Are you using the screws in the frame?
Posted : 18/09/2019 10:45 am
 nbt
Yes, just using the fittings points on the bikes - there's already mudguard mounting points in the expected location on the rear, the front if awkwards but not that bad
Just recalled, I had to drill a hole in the rear guard to allow it to fix to the seatstay bridge as the bolt there is on the underside of the bridge. No biggie though
Posted : 18/09/2019 11:06 am
Great thanks.
On a completely different note, do you have mechanical or hydraulic brakes?
I'm on mechanical and am dreading adjusting them, I've only had it a couple of months.
Really liking the XLA, I only bought it on a whim and have found I'm using it more than my MTB.
Mick
Posted : 18/09/2019 11:26 am
 nbt
I've got the 1*11 hydraulic version. Cracking bike for the money
Posted : 18/09/2019 11:28 am
I use those SKS/Blumels guards on my disk brake road bikes. Doing the bending round the caliper is easier if you cut one of the stay off and just use a silgle on the brake side. Still enough stiffness for adjustment and no rubbing. Looks better than a massive long sticky out bolt too IMO.
Posted : 18/09/2019 12:50 pm
Do know what size you have? There seems to be:
700/35
700/42
700/45
700/53
I'm running 35mm tyres.
Posted : 18/09/2019 1:03 pm
 nbt
I've 700C*35mm tyres, I use 700/45 mudguards - accepted wisdom is tyre size plus 10mm
Posted : 18/09/2019 1:16 pm
Thanks
Posted : 18/09/2019 10:37 pm
