Fitting Hope Press ...
[Closed] Fitting Hope Press fit BB without the "proper" tool?
5 Users
Looks like there's no reason why a headset press shouldn't do the job for the cups.
I assume the same for the drive side bearing, making sure that the press goes on the outside of the bearing.
But what about tightening up the sleeve? it looks like a pretty large size hex fitting. What are people using?
Posted : 03/11/2014 7:47 pm
Bump for the morning peeps.
Posted : 04/11/2014 7:12 am
I've fitted one fairly recently without the Hope tool.
Homemade headset press then can't quite remember how I nipped up the sleeve...Maybe a set of pliers pulled open to jam against the flats... something like that.
Posted : 04/11/2014 7:31 am
Do you know the size of the hex in the sleeve?
You can get pretty big hex key/sections for removing motorcycle front wheels. If you know the size these may work.
Have a look on ebay.
Posted : 04/11/2014 7:38 am
me, [url= http://singletrackmag.com/forum/topic/anybody-using-the-hope-pf41-bottom-bracket#post-6434985 ]here[/url]:
I used the hex part of an old BB tool but it wasn't quite the right size and was worried it'd slip and **** everything up.
Hate to say it but the proper tool is probably what you should use
Posted : 04/11/2014 7:48 am
 br
Yea, sod it just slap it in - it's not like Hope know what they are doing... 🙄
Posted : 04/11/2014 8:05 am
Cheers chaps,
I guess the sleeve doesn't need to be that tight, just nipped up a little to help stop the cups moving back out?
It the first time I've needed to deal with a PF41 BB, so I probably will get the tool at some point. If the tool takes a while to arrive, might need to get it fitted before hand in order to get the bike rideable.
Posted : 04/11/2014 8:27 am
