Fitting chainrings:...
[Closed] Fitting chainrings: YouTube suggestions please
9 Users
Please recommend a YouTube instructional video for replacing chainrings on a triple chainset.
I've never done it before
Thanks
Posted : 24/02/2016 8:11 am
Er, remove cranks. Undo bolts replace rings. Probably something on the park site. Only tricky bit is getting the tool for the back of the bolts. Nothing complex to it at all.
Posted : 24/02/2016 8:16 am
Little tip from me after a recent mishap... Make sure the hex key is properly seated in the bolt. They can be very tight & are very easy to round. The metal seems very soft. Secondly wear thick gloves...when your hand slips and knuckles punch the chain ring it hurts. A lot!
Posted : 24/02/2016 8:20 am
The writing on the 2 smaller rings goes fscingfacing inwards towards the frame and there should be a little tab on the inside of the rings, just line them up. The big ring is easy to fit coz there's a little metal pin that sticks out, put that facing outwards under crank as it stops the chain falling past. It's all dead easy. 🙂
Posted : 24/02/2016 9:15 am
 Yak
All as above. Tabs line up with the crank. Use a proper chainring bolt tool, or something that properly fits the slots too. (more important for the bolt removal than the doing up.) I also threadlock the bolts.
Edit - a steel ruler is a reasonable bodge substitute for a chainring bolt tool.
Posted : 24/02/2016 9:22 am
The writing on the 2 smaller rings goes facing inwards towards the frame
I've always done outer and middle rings with writing facing outwards, inner ring facing inwards. It's pretty obvious though due to the shifting ramps etc, only tricky one is the little ring because that's normally just plain sided.
Posted : 24/02/2016 10:11 am
Park tools and the instructions from the manufacturer. Not all rings are arranged the same way (text in/text out).
Posted : 24/02/2016 10:18 am
OP have you even tried typing "replacing chainrings on a triple chainset" in to Youtube search and looking at the results?
Posted : 24/02/2016 11:53 am
Wrap a chain around the big ring. Then if your hand slips on to it, it does't injure you as much.
Posted : 24/02/2016 12:41 pm
