These parts are on their way to me for my first singlespeed bike - fancied something a little bit different and fun.
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
I think the rest of the parts had better be black, at least it will stand out from the crowd.
Just need to source some other bits now. Anyone have any single speed specialist supplier recommendations.
Charlie the bike monger
[url= http://www.charliethebikemonger.com/ ]CTBM [/url] a regular poster on here and a genuine nice guy in the flesh too, likes and beer and to dance badly as well
Grrrr beaten to it by Taz.. Evening mate by the way
What them up there said...and yeh that other kit is very, very drab...if everything else in your life is green, otherwise... 8)
evenin ron...how's my favourite porn baron?
Well I like beer and dance badly too so I guess Charlie the bike monger is the one.
all good Taz, just been sorting out a few event dates for this year, so photos to follow,
So what else you going to fill your empty garage with?
Worth checking out Velo Solo as well. Reasonably priced and very efficient.
you're never gonna lose that in the snow
Where do you put the brake?
Velosolo, nice selection of parts and quick service
Umm yes good point by Mattbee..... Where do the brakes go??!
Clipless pedals better than flats for SS.
Brakes = calipers
People do realise that is a road frame don't they?
But there's no hole on the fork for the bolt to go through.
rOcKeTdOg - Member
Unless everybody decides to take a piss near it...
I think you get a triangular wedge to fix that problem
Nigel
Shameless plug but if its a 29er and you're in need of wheels, I have a set of excellent condition single speed wheels up for grabs, could do either rear or both. They're Crest rims on hope hubs with 10mm bolt up rear.
Nowt rong wiv da colour, almost Klein retro fade stylee.
Almost.
Have fun and welcome.
Grow a beard.
This was one of my major concerns. 😉
Rear only, caliper.
That may well be the case but I don't do clipless.
This will be a flatland fun bike, I don't have the fitness levels for serious singlespeed use. It will mostly be used for cycle path use around Cardiff, I have other bikes for other stuff. I'm building it coz I can!
Some manufacturers BS:
[i]The perfect cross between a commuter and trick bike. It features a slightly raised BB and lowered top tube lowered making this frame easy to ride and fly. For 2013 we revised chainstays shape to fit your favourite fat tyres (now up to 45c size).
The Analog has many of the features that we used to make the lightest dirt jumping frames on the market: the Majesty and Suburban. You will get an oval machined head tube for weight saving, with a campy style headset standard, a totally unique high-end tube-set with offset multi butting, 100% cromoly tubing made by Tange and what's most important, trick specific geometry.[/i]
HAha I just liked the colour 🙂
You probably do or soon will, and I wager you'll be back in a few weeks thinking about an off road SS.
I like the colours of this, let's see a built pic when you're done!
It may be some time before I finish building this, having spent many oodles of moneys on bike parts over the last few months on upgrades for my Giant Anthem and Mongoose. Her indoors thinks that stuff for the house has a higher priority. 🙁 I had to tell her about this as she'll not miss it when it comes, its hard to camouflage. So the rest of the build will be a gradual process as and when I can sneak parts in!
Oh and thanks for the suggestions of Charlie the bikemonger and Velosolo - duly bookmarked. Any others out there?
You don't always need to look for SS specific parts. Most are interchangeable. Eg, take two rings off of a triple and as for the rest, don't buy any gears. I also suggest a fixed rear wheel. Much better than trying to stop with a rear brake. If your only going to have one brake, front is always better on a fixie.
That'd make a real nice fixie
any road front wheel will fit but you'l need a track rear wheel with either fixed or freewheel. freshtripe is also good shop. Just google what you need loads of shops out there. Charlie and Velo are the most popular.
fixed + flat pedals with no straps = gonna have a bad day.
freewheel with no brakes = gonna have a bad day.
but its your bike and your face, do what you want and try not to run into anyone else.
OK, build of this bike has started with a few bits trickling in. Waiting for wheels from Single Speed Components and a few other bits and pieces. Got some v-brake clamps for the forks so will have front brakes. Apart from frame, forks and grips everything else will be black. Look forward to finishing this and giving it a try, been wanting to try singlespeed for a while 🙂
I don't think its too drab!!
Different cable pull needed for caliper and V brakes???
Liking the colour scheme tho
Yep, the Dia Compe levers I'm using can be set up for either.
