Thinking of going Portsmouth st malo as a foot passenger with my bike
But just a little worrried about how it will be stored/ secured during the crossing
Just after people's advice or experience
Thanks
If Ferries in Canada and Denmark are anything to go by you should be fine, bikes get put up against the hull normally where you disembark on a RoRo. Well out of the way of things. Usually first on and first off as well. Ramps can be steep and slippy, watch out for trucks coming past you at warp speed as you try and figure your way out of the port.
The bikes are lashed to "bike hoops" like you get in bike sheds, ropes are provided but usually very greasy.
I usually take my own strap to tie it down. I also use an old Velcro watch strap around the brake lever to limit the amount of movement, works on trains too.
If your not loaded up, pannier etc, you might want to take some form of padding (pipe insulation is light) to protect the paint.
Portsmouth/caen you get to board first, everyone is watching as you "attack" the ramp so hit it fast. Look out for the steel plate as you enter the hull, its slippy as hell and often wet! Once on board my bike and a few others were lashed to railings with some rope and pipe lagging to protect frames. I took some bungy cords just to make sure nothing moved around and a small lock to be sure.
I travelled with a road bike and huge suitcase and they lierally wanted me to ride the bike onto the ferry. After much protestation and a speaking with the supervisor I convinced them that this was impossible and frankly a ludicrous proposition and was allowed to walk the bike on like a normal passenger, suitcase trailing in one hand and the bike in the other.
When on board staff were helpful and I was able to lock my bike directly to the luggage rack inside the little luggage storage room where you keep your cases. This room was then locked for the duration of the crossing. Nice!
It was an expensive carbon road bike so you can understand my concerns.
This was all from Portsmouth to St Malo and I had the same experience minus all the initial faff on the way back.
Hope this info helps. If in doubt put your foot down 🙂
Fr0sty
Our family of four took the Poole-Jersey-St Malo Condor route. Went on first, tied up well in a good secure area. Worked out fine. Left most of our panniers on the bikes.
Same on the way back apart from swapping boat in Guernsey.
Off to France next month Via Caen so this thread is perfectly timed.
I did dover calais once - ride up the ramp - tie off against a wall near the cars - ride off the ramp
The deck guys were very good at keeping motorists well away from me and giving me clear instructions
I would have no issues about doing it again
Fr0sty- what did you do at the other end with the suitcase??
Put it in the car that was waiting for me!
Needless to say I wasn't touring 🙂
Cool thanks all , sadly it will be a big all mountain bike so no luggage to protect it
But that tip with the brake lever sounds great.
