Faulty Bike or Not?
[Closed] Faulty Bike or Not?
10 Users
Hi all,
I recently bought a Rose SL 2000 pro bike which I have still not had the chance to ride. Just a few nights ago, as I was assembling the bike, I noticed that there are quite a lot of paint imperfections on the carbon forks, I myself could look past some of these because I think that a lot of bikes are plagued by this due to the process of painting carbon parts (I might be wrong, I am a newby), but what I saw next made me unsure if I just had a bad apple...
As you can see from the picture I have attached, on the bottom of the fork, you can see a clear dent where the wheel hub attaches.
Bearing in mind that I have only had this bike for about 5 days, do you think it's worth sending this back and getting it exchanged?
What are your thoughts on the dent and the pain imperfections?
Thanks,
Ohms.
https://drive.google.com/file/d/0B-6Za_hDLx2mQ2VxT05JMno0QS1sRGNMdlNPUnN1Z3YzWFpj/view?usp=sharing
https://drive.google.com/file/d/0B-6Za_hDLx2menZ3Zml4SnpuM2lpM3d4SGxfaWNyUF96eXhr/view?usp=sharing
https://drive.google.com/file/d/0B-6Za_hDLx2mb3Z1U181eTlzWkJGRWhLVFA0LWFMV011c1Z3/view?usp=sharing
Edit: looks like the images didn't work, so I switched them for links.
Posted : 06/08/2017 10:51 pm
The "imperfections" are a natural result of the carbon layup process. There's no paint.
That little "dent" (assuming I'm seeing what you're referring to) looks fine too.
Posted : 06/08/2017 10:59 pm
As Scotroutes said that's not paint imperfections - that's what carbon looks like if you don't paint it. That's a 'raw' UD carbon finish. Sometimes it's painted with a grey paint to make it look tidier, sometimes not. It's not a fault. As for the dimple (dent) I'd not worry about it. If you strip the paint of an alu bike there's a good chance you'd find some filler covering over a small imperfection- carbon has the same but as the forks are raw there's no hiding it. These are hand laid products prone to small imperfections. On a 10k bike they'd probably reject it. You bought a rose which is very good value, they can't be quite so picky all the time.
Posted : 06/08/2017 11:13 pm
Fin from Rose UK is a top bloke... drop him a line if you are worried - I think any emails for Rose UK go through to him anyway.
Posted : 07/08/2017 3:27 am
Perfectly normal, moulding witness marks and decals applied over bare UD finish.
Posted : 07/08/2017 8:46 am
What they all said.
Posted : 07/08/2017 10:54 am
Thanks everyone for the quick replies, much appreciated.
Yea I agree with dovebiker that the marks seem to be only around the stickers, with some shiny spots (probably poorly applied clear coat) dotted around the forks.
I was just worried that come time to sell the thing, I would get comments about this stuff..
Those are definitely not moulding witness marks tho (unless the mould is of poor quality). 🙂
Posted : 07/08/2017 5:41 pm
i had a rapide rl2 disc which had a faulty carbon fork which resulted in me hitting the ground pretty hardonly had it 2 months and was only its second ride out..
Posted : 07/08/2017 6:03 pm
I am also worried about that. A notch like that, even though it appears small, can significantly impact the performance of a weight bearing component like that.
Posted : 07/08/2017 6:37 pm
hms93 - Member
MWAHAHAHAHAHAHAHAHAHAHAHAAA - you'd better not look at my carbon forks then.
Keep an eye on it to see it's growing but I wouldn't give it a second thought.
Posted : 07/08/2017 7:32 pm
You wouldn't be laughing if you studied fracture mechanics in a mechanical engineering course. A notch just 1 micrometer deep can increase the stress concentration significantly in a load bearing parts even causing it to fail prematurely. Usually the size of a notch increases the stress by a^0.5 where a is the notch size. In lab testing to measure fracture toughness of a material, we induce notches in increments of 1 micrometer thickness.
I am not saying that what I have is a notch on a weight bearing section, but it's something for me to keep an eye on.
Posted : 07/08/2017 8:13 pm
Ohms, I would say that your knowledge of fracture mechanics is probably why your a bit more worried than an "average"rider might be.
I recently got my first (second hand) carbon fame and was very precious about it at first to be honest. I noted every tiny imperfection and got all concerned about it. After having ridden it many times now I just don't worry about it anymore. I do use a torque wrench now but that's the only change really.
Carbon is really rather nice actually and a lot harder than I thought it might be.
Enjoy the new bike mate! 🙂
Posted : 08/08/2017 4:24 am
If forks were built such that a 0.5mm imperfection on a brand new pair caused failure then there would be a lot of dead cyclists.
Those marks are the carbon, it's not the clear coat.
Posted : 08/08/2017 5:02 am
Poopscoop, you are probably right mate, I think I am worrying myself. Thanks!
njee20, I am not saying that it will immediately cause a fracture, I am saying that notches reduce the yield strength of a material. So basically a notched frame is a weaker frame (or one that is more likely to fail earlier and has a shorter life span). I am closer to the 100kg limit that probably a lot of you here though, so I worry a little more. 🙂
Posted : 08/08/2017 5:35 pm
Ohms, I'm pretty much spot on 100kg at the moment too. 😉
Posted : 08/08/2017 7:12 pm
