Fatty curious - BB ...
[Closed] Fatty curious - BB and crank options?
7 Users
Really like the idea of the On One Fatty frame/fork/wheels/tyres combo but I'm at a loss trying to find a sensible (cheap) crankset option. What is there?
Posted : 28/10/2013 7:32 pm
Merlin have Truvative Holtzfeller chainsets for £50 at the moment. Comes with a standard bb you could sell on. 100mm ones are about £30 from Germany. You can get away with a 32 tooth max on middle ring with these. I got the double and bash in case, but am running a single ring and guide just fine.
Posted : 28/10/2013 7:55 pm
Raceface chester will run 2x on a fatty!
Or...
Middleburn
FSA comet (if you can find one!)
Etc etc
Posted : 28/10/2013 8:03 pm
Is the holtzfeller bb a GXP then?
Posted : 28/10/2013 8:09 pm
No, its a Howitzer interface - similar to Isis, but (so it seems at the moment) a bit more resiliant.
Posted : 28/10/2013 8:50 pm
Don't bother, the BB's need replacing too often and they are expensive with no options. Just get a Sram X5 crank. £125 for cranks, BB and 22/36 rings and loads of BB options when you do wear them out.
Gis a shout if you want one, we've got loads in stock.
Posted : 28/10/2013 9:02 pm
OK, got it so howitzer is its own type of interface and x-type is yet another which is used by raceface.
Tim, which ones fail early? Howitzer? I couldn't find the X5 with 100mm BB for sale anywhere, good to know they exist, I'd written it off as nonexistent.
Posted : 28/10/2013 10:00 pm
I have some FSA comets if you want them for relatively cheap, BB30 mind.
Posted : 28/10/2013 10:39 pm
Thanks, but I'm just looking at options at the moment, I'm trying to work out whether to get the full bike at £999 or the £499 combo. It's all getting a bit spreadsheet-tastic but I think it will be the combo, I reckon I can do 2x10 XT with XT brakes for only £130 more.
Posted : 29/10/2013 8:55 am
I wouldn't say they fail early, but the Howitzter BB's are ISIS and it's a receipe for shortgevity. Big diameter axle in a small casing means tiny ball bearings.
The X5 100mm option is a cracking bit of kit for the money.
Posted : 29/10/2013 9:04 am
I agree, I've just fitted one to my Muk to replace a creaking old ISIS. Much better and nice to know I'll have a choice of outboard bearings when these ones go.
Tim, do you know if Sram do a single ring version?
Posted : 29/10/2013 9:08 am
Er, yes but it involves taking the granny ring off yourself 🙂
Posted : 29/10/2013 9:16 am
What I meant was I have the double and it spaces the rings out further. I wondered if there was a single ring specific version or if there's a triple and I'd remove the granny and the outer to keep a decent chainline. Hope that's a bit clearer 😳
Posted : 29/10/2013 9:30 am
As far as I know there isn't a single specific version, but you can play with spacers and move most stuff around to get the chainline you want one way or another.
Posted : 29/10/2013 9:50 am
Cool, I'll either do that or maybe go for the Race Face turbines.
Cheers 🙂
Posted : 29/10/2013 9:54 am
Turbines are lovely. We've got those too and they will definitely cover more bases in terms of adjustment.
Posted : 29/10/2013 10:31 am
I'm using the Race Face Chester on my Fatty its an external BB so when it wears out replace it with either the same or Shimano - it retails at £120 no rings - It's running 22/32 loads of adjustment due to all the spacers it comes with - a nice and stiff crank 😀
Posted : 29/10/2013 4:17 pm
