Looking to replace my original fatty crank on my on-one.
It's a good opportunity to drop some weight so what do you recommend ? Race face any good?
Edit- this will be used with a single 30t chainring
Got am aeffect on mine. If you want to go lower than 30T a cinch might be better
I've got SRAM X9 Fat on mine, they're a spider style crank so you can fit tiny rings, I expect got a 28t sram-x-sync steel one.
They're nice looking cranks
Aeffect are good, got them on mine. 24mm means you can can use Shimano BB.
You can use direct mount rings (not sure what RD means about cinch?) or a spider. I've gone for a spider, got 104mm on other bikes, and I swap around SS/ gears from time to time, so matchy-matchy fine for making easier swap times.
rOcKeTdOg - Member
Aeffect ARE cinch interface - I have a 28t on mine
