Fatbike wheels
[Closed] Fatbike wheels
12 Users
Hi,
Behind the times I know, but what would you recommend?
I'm looking for 80 mm ish rims on 150/15 and 177/12 and easy tubeless.
Thanks!
Posted : 09/03/2018 7:28 pm
Hope fatsno hubs, only had Specialized fat boy SL but they are very similar/almost identical to DT BR710s and they seem pretty good, if a faff to tubelesserise.
or a DT BR2250 wheelset.
or if I was flush, HED carbon rims with aforementioned hope hubs
Posted : 09/03/2018 7:35 pm
Yep, BR710 on Hope fatsno for me or the DT BR2250 wheelset (which is the same rims on DT Swiss hubs) if you prefer.
Posted : 09/03/2018 7:50 pm
ICAN Carbon wheelset. Light, strong, tubeless easy and very resonable price.
Why buy some hubs and separate rims full of holes, pay for a wheel build and struggle to make it tubeless? And pay more for it all than the ICAN stuff?
Posted : 09/03/2018 8:10 pm
Mulefut rims on anything, really easy rims to tubeless try  http://www.justridingalong.com/
Posted : 09/03/2018 8:11 pm
Hope Fatsno hubs with DT Swiss BR710 rims here. Ludicrously lovely things they are - brilliant.
Posted : 09/03/2018 9:15 pm
https://singletrackmag.com/wp-content/uploads/2018/02/weight-weeny-wheels-for-fat-bikers-reviewed-dt-swiss-br2250-wheels/
They are light but I was a little underwhelmed by them when it came to riding them hard. Read the review and you will see my thoughts on them.
I would avoid HED  having read drJon's experience when he broke his. Have a look at his blog, drjon's wanderings. Jon knows his onions and I trust his opinions.
What kind of riding are you planning on doing? Surly rims tend to be a little heavier but I have singularly failed to dent clown shoes and rolling daryls. The My Other Brother Daryl's look to be a good compromise for weight, strength and tubeless compatibility.
I also liked the Sun Ringle Mule Fat's on my test Fat Caad.
Hope this helps?
Sanny
Posted : 09/03/2018 9:52 pm
 JoeG
Mulefut rims +1
Posted : 10/03/2018 12:55 am
You'll not get the br2250 wheelset in a 177 rear end - it's only 190/197.
But br710 rim is the same with a 177 hub. Not many about so hope seems to fit the bill and i believe is upgradeable to other widths
Posted : 10/03/2018 5:40 am
Hope fatso are the goto fat bike hub of choice. But there are others out there. DT Swiss if you want faster or changeable engagement speeds, Halo and salsa are a little cheaper but less bling, and many more.
Rims, 80mm would give you the choice of almost any brand on the market. Personally I have Fatlab's which were a sinch to set up tubeless (pop up first try every time). DT Swiss seem to be a goto choice due to low weight and relatively low cost.
Posted : 10/03/2018 8:36 am
Thanks everyone,
I'm looking to build up a do it all sort of fat bike for use on the south coast natural trails, heaths, beaches, caggy bridletracks etc and am a heavy gung ho rider so would not want light weight at the expense of reliability/strength.
I'd like Surly MOBD rims but can't find any complete wheels or builders using them, otherwise I guess Mulfuts look good.
Or perhaps the Alex Blizzerk 90/Salsa hubs builds that Merlin are offering, has anyone used them and would 90mm rims be too wide for 3.8-4.3 tyres )I'm thinking Nates or Edna's).
Posted : 10/03/2018 10:23 am
nope. It’s 170/177 or a different hub for 190/197 the difference is QR/Thru axle, like 135/142
Posted : 10/03/2018 10:45 am
rickmeister
Because you can build up the ICAN rims with DTSwiss butted spokes and a Hope hub for a far nicer wheelset. đŸ™‚
Posted : 10/03/2018 11:04 am
Mulefats here, only ones I have ever run though.  Running 80mm and 3.8 tyres. Easy to on tubeless.
Not sure but I guess there is only really a step change if you go with carbon rides.
Posted : 11/03/2018 1:38 am
