Fatbike hub end cap...
[Closed] Fatbike hub end caps help
5 Users
I have a 2016 salsa beargrease that came with novatech d201sb front hub 150mm spacing. As it came it had a 150mm qr fitting but the hubs are convertible with different end caps. I have now got a bluto for it so need to change to 150mm 15mm axle. I cannot for the life of me work out what end caps I need. I bought some but they don't fit. The qr caps come off and leave a 15mm hole but its only 140 wide with no caps
Anyone any clues which ones to get or where I can get help with this?
Posted : 31/07/2019 9:28 pm
You could maybe drill out the QR caps?
good idea but it won't work - the qr caps fit inside the hub so drilling them out would leave next to nothing
Posted : 31/07/2019 9:31 pm
A quick search gives a few aliexpress links. SJS cycles in the UK do a lot of Novatech spares but I can't find the end caps for your hub. It might be worth contacting them to see if they can help.
Posted : 31/07/2019 9:49 pm
thats as far as I got. I got one set I thought was right from sjs but they didn't fit.
Posted : 31/07/2019 9:54 pm
Novatec don't list a 15mm end cap for that hub.
https://www.eshop.novatecwheels.eu/eshop/side-caps/c-38/Filter125Value1/1/Filter126Value4/1.xhtml
Posted : 31/07/2019 10:11 pm
Apparantly its the same as one of their other hubs in fitment. You can buy the hub with 15mm end caps and its advertised as convertible
I have now emailed novatech - dunno why I didn't before. Doh!
Posted : 31/07/2019 10:27 pm
Incase anyone is interested I couldn't get an answer out of novatech EU but novatech US were very helpful and got me the right part number. Excellent service from Novatech US
Posted : 12/08/2019 9:52 pm
Hi tjagain. Would you mind posting that part number and where you purchased the caps? I'm in the same boat. Thanks!
Posted : 28/01/2020 5:26 am
I'll sort this out when I get back from work at 8 pm
Posted : 28/01/2020 6:14 am
Sweet thanks
Posted : 28/01/2020 7:05 am
Side cap FRONT 15-P, AL-BLK, L/R, MULTI for D791SB-PRESSED ON
https://www.eshop.novatecwheels.eu/eshop/side-cap-front-15-p-al-blk-l-r-multi-for-d791sb-pressed-on/p-329695.xhtml
Posted : 28/01/2020 8:33 pm
Thanks so much!
Posted : 28/01/2020 10:43 pm
