Fat Bike ~ Thin Bik...
[Closed] Fat Bike ~ Thin Bike = Same Bike
10 Users
I had to double check the username to make sure it wasn't one of Al's projects.
A solution looking for a problem?
https://www.crazyguyonabike.com/doc/?o=Sh&doc_id=13772&v=R
Posted : 26/11/2014 8:00 pm
 Andy
bet that will corner well 😯 EDIT and not much risk of pedal strike from the lowered BB either 😆
Posted : 26/11/2014 8:04 pm
It wouldn't take much of a turn to find out.
Posted : 26/11/2014 8:07 pm
 Andy
Although have to say my Mukluk rides really well with a pair of 29er rims laced onto Fatsno hubs. Means when I go on campervan holidays 1 bike can be used for both beach/off road and for long road rides as well 8)
Posted : 26/11/2014 8:09 pm
Lots of words to say i bolted a rim to a rim. eh ?
This is why i went for 47mm rims , can still stick on normal tires when i want,
Posted : 26/11/2014 8:16 pm
 cozz
interesting, but he misses the point
if you were going to go touring on a fat bike, you prob wouldnt do it on one with 100mm rims
you would be best using 65mm rim like marge lite, they will run his 4.8 tyres, and then use a 2,5 maxxis hookworm or similar
ive done coast to coast on hookworms on 65mm rims on a pugsley
Solving a problem that doesn't exist.
Posted : 26/11/2014 8:18 pm
 JoeG
I'd be afraid of a rock, pothole, or something else denting or otherwise damaging the exposed fat rim that is sticking out in the open...
Posted : 26/11/2014 10:19 pm
It's the answer to all STW's what tyre for that rock or root over there, you can literally swap all day long to your hearts content touring literally inches per day.
Posted : 26/11/2014 10:24 pm
[quote=mikewsmith ]
Posted : 26/11/2014 10:25 pm
scotroutes - Member
He covered that. Touring in Oz and also doing the Canning Stock Route.
Makes perfect sense.
Need to be bonkers to do that, of course.
Posted : 26/11/2014 11:42 pm
"Being a Master mechanic"
is master a euphemism in this case?
Posted : 27/11/2014 7:53 am
He's a lateral thinker certainly - plenty of stuff out there of what he has done before on all sorts of bikes. I think he is touting himself for the position of cycling's senior eccentric vacated some time ago by the sadly departed Mr S Brown.
Posted : 27/11/2014 8:11 am
