I've got a Patrol, Arc30s, and a DHF2.5 WT on the front.
I want something for the rear for dry weather/hardpack type jazz.
Generally aggressive trail riding/jumps/DH on local stuff and also, crucially, to look after me on the Ard Rock/BPW/Stile Cop/occasional Follow the Monkey as well.
I'm thinking Minion SS or an Aggressor. Would I regret the SS? I ran HR2s last summer and although I like them as a general all rounder, I want something more specialised for the drier month(s).
I'm erring toward the SS for the extra speed. Will I regret it?
Rock Razor Super Gravity Trailstar.
Minion ss's don't play well with wide rims (as do most 2.3 maxxis tyres).
I'm running a specialized slaughter grid on the back at the moment for the dryer months, the rock razor is decent as well.
My mix and match OCD is twitching :/
I'm going to go all out and say no Schwalbes in fact. My mate's had several different variants, and even with not particularly rocky south east riding, they seem to just fall apart. In fact, the one he used at the Ard Rock last year was practically new when it went on, and after the even looked like someone had taken a machete to the side knobs.
Enigmas - what's the complaint with the SS on wider rims?
I really like the Minion SS. It takes a little getting used to and there's times when it feels pretty iffy (dry crumbly fall-line steeps, bottom of innerleithen sort of thing, can be exciting) but semi-slicks have a great combo of mental speed while still having corner grip.
(I've not used a Rock Razor, I want to give it a try) On wider rims the Minion puts its sideknobs down very early which is kind of a mix of good and bad.
fitted a minion SS on saturday. started raining. stopped on wednesday.
rode tuesday night in the shittiest conditions and it was pretty good. in that I expected to be all over the place and wasn't.
rode it last night again in the mostly dry and its great. like riding with a tailwind but still bites when you crank it over.
OK, cheers guys, is the Silkworm/EXO variant going to be OK for the Ard Rock type conditions? It's going to be my first North Yorks type foray.
I'm a reasonably aggressive rider, but I weigh ~10 stone.
Have any of you used the Aggressor to compare it to?
I'm going to put it out there that in 20+ years of riding I've never slashed a tyre. I've only gone tubeless in the last year though.
Rock Razor Super Gravity is slightly heavy but offset by the tread. It is also surprisingly versatile in a range of conditions and is definitely tough (I've ridden it at Antur Stiniog and Revolution without issue).
I also have high praise for Maxxis Ikon 3C 2.35. I had them front and back from January > May (bike just sold that had them on) and they were stupidly rapid. Perhaps not ideal on the front but OK. As a rear though; awesome.
Rock Razors work far better than you expect them to in most situations, even wet. Only real weakness is braking grip on loose ground (wet or dry), which makes them slower overall on some of my local trails. They are very, very fun though.
My experience is based on unfashionably narrow (23.5mm internal) rims though.
EDIT: just saw that Ardent Races (like an Ikon with bigger cornering knobs) come in proper sizes now. The 2.2 version is excellent, but skinny, so I'd love to try one of those too.
another 2 rides on the minion SS and i'm really rating it, although I walloped it off a piece of granite last night and holed it. thought I was going to have to put an anchovy in it but seemed to seal up and hold air overnight.
Minion SS is my go to tyre for the summer and I really like it. You can lean on it surprisingly hard
Butcher / Slaughter combo here. Actually ran it through the winter because I couldn't be bothered to change it. Surprisingly good - actually prefer the Slaughter to the Purgatory. Very nice, chunky sideknobs (same as the Butcher - corners very well) and rolls well in a straight line. Like any SK tyre its major failing is deep mud or hard braking in a straight line; however I'm trying to get into better habits and brake more effectively (which also transfers more of the braking duties to the front) so the second point isn't really a huge deal when running a decent front tyre.
I've got the aggressor and am getting on well with it, predictable and corners well but is a lot faster rolling that the hr it replaced
Are maxxis doing a wider version of the aggressor yet? I like it but a bit more width would nice.
The minion SS is designed around a 23mm rim (a maxxis designer confirmed on mtbr). On wider rims it's too square to the point that the side knobs touch the line going in a straight line, making it feel draggy and wear fast.
I swapped mine for a slaughter which is much better suited for wide rims.
I should mention this is also on easton arc 30's.
I asked a similar again recently and went for the minion SS in the end, silk worm version.
Pretty good!
Does roll quick and more than grippy enough for my mincing around! 🙂
Specialized Butcher/Slaughter here as well.
Use them in all weather as I can't be bothered to change. Just wish I went for the Grid casing instead of trying to save a few grammes. The Control is fast and light but deforms a bit in hard corners.
They're really coming into their own now the trails are hard and dry.
2.4 Ardent
Agressor or tomahawk probably, enough grip but fast enough
Ardent Race is working great for me with a Minion DHF up front.
Maxxis DHR 2, 2.3wt on the front and Maxxis Aggressor 2.3 on the rear. Great combo imo for a multitude of surfaces found riding lots of natural stuff round Wales, The Peak, The Lakes and Spain.
Pretty fast rolling, lots of predictable corner grip, sheds mud well when it's wet and tends to find grip unless it's proper sloppy/claggy. Seem to wear well too but side walls on the DD version start showing the threads after a month or so.
Going to give the WT version a go when that comes out over here and see if the ride characteristics are the same
Carlos
Trail boss is ace, bloody quick, and has better straight line traction, but doesn't have the same grip leaned over as the SS ones already discussed, as it doesn't have the same aggressive edge knobs.
It's a good option, and I like the tough fast casing, as I'm a big bastard and like riding rocky stuff.
I'd like to try a Slaughter, as I rate the grid casing, but EXO isn't tough enough for me.
I'm going all in with a Slaughter Grid on the back for the EWS this weekend. Last time I tried a semi slick was the Rock Razor which had a lifespan measured in minutes.
Borrowing a set of 30mm ID rims so hopefully they work out ok. Might go for the Butcher Grid on the front too.
Nobeerinthefridge - MemberTrail boss is ace, bloody quick, and has better straight line traction, but doesn't have the same grip leaned over as the SS ones already discussed, as it doesn't have the same aggressive edge knobs.
Yeah, I just had a first ride on the trailboss and that's exactly how it feels too. If you could glue on the side knobs off a minion it'd be a fantastic tyre
Another vote for the Ardent Race.
Currently running one on Flow EX rims paired with a HD front.
It works well but not a huge amount of grip under breaking ...... #skidzarentjustforkidz
Isn't this where the Aggressor wins over other 'intermediate' tyres like the Trailboss or Purgatory for instance.
Not for me it doesn't, if you're 10 stone and ride light, then yes.
Maxxis or now on the 'front tyre only' list, just below Schwalbe... 8)
I run a Minion SS in the summer on ASC 30 rims and like it - it's worn well so far (into it's second summer). On steeper, loose stuff it can be interesting but on harder packed stuff it works really well.
If by ride light you mean mince then that works for me 😉 Not had problem with EXO casing tyres, oh that's done it now 😕
Ardent race has a pretty flimsy casing and the tread isn't that high. Its a good xc tyre but wouldn't want it on the back for anything steep/loose.
At Ardrock last year I ran a DHF on the front and SS on the back. Conditions were dry, this year if its wet there will be a minion dhf on the back as well.
I have an aggressor on the back of the reign at the moment, its not as quick rolling as an SS (but quicker than a HR2/DHF/DHR), but way more braking grip, side bite is a little bit less than a minion.
For trails which are steeper (Inners/Shropshire) I like something with a bit more braking traction, then not having to worry about braking when I need to!
I tend to just use a worn down rear tyre in the summer. Im planning on riding my worn Purgatory or possibly a worn Rubber Queen this summer.
The Purg may not be the best when it comes to braking on the rear, but the consistent element I've found with all of the more aggressive modern Specialized tyres (Butcher, Slaughter and Purg) is they have stacks of cornering bite. I've not used an Aggressor so couldn't comment, but it does look like a nice tyre. Compared to a Maxxis Ardent I feel the Purg bites better in the corners and is pretty equal when it comes to straight line grip.
Whoa! That picture of the SS on a wide rim has put me right off!
I'm not that keen on the idea of an Ardent, I'm not sure they're aggro enough. Aggressor is looking like the best bet at the mo, or a Purgatory.
And I am a 10st weakling, if that helps!
I'm an idiot - it's the Slaughter that's the equivalent of the Minion SS isn't it? Not the Purg?
Are these any cop? I had one on a demo bike last year at Friston and remember being reasonably impressed at how it held on soft stuff for such a low treaded tyre. I'm not sure I was really pushing it and didn't have much to compare it to at the time though.
Purgs on the other hand are only £20 from JE James...
Minion SS is great on a Flow EX (25.5mm internal), similar shape to that Rock Razer on a 35mm rim. Hopefully they'll make a WT version soon for those of you on wide rims because it's a great tyre!
I didn't get on great with the slaughter grid, it felt really similar to the minion for braking and cornering but it seemed way down on pedalling traction- spun up on technical climbs where the minion doesn't seem to (hard to really compare fairly as conditions vary so much but innerleithen's annoying step climb was a pain in the nuts with the slaighter)
I'm honestly not that bothered about climbing traction. I mean, it's handy, but if it's that 'technical', I'll probably fail in the technical skill bit, and just get off and push 😀 As long as it's handy when it's up to speed on the downs/flow, I'm good 😀 So from your description, it sounds dead handy!
Pretty much. Can't comment on a comparison as not ridden a Minion SS.
Purg is a meatier tread, but doesn't seem to brake any better in a straight line (in my experience). Does roll well tho.
Worth getting teh Grids if you ride anywhere rocky too.
Bontrager XR3 or SE3 if you want it a bit tougher?
Not as fast as the others mentioned but pretty good for a UK summer.
I prefer the doubledown aggressor to the tough 2.2 trail boss, it lighter, rolls about the same but corners much better.
I found the trail boss a little small and to get the cornering grip had to lower the air pressure too much. I've a few dents in the rim to show for it...
The aggressor seems a really good match to the minion dhf on the front, which isn't a surprise at all as that's what it was designed for.
I use a 2.4 TB, And there's no way on earth the aggressor has tougher sidewalls, even the DD.
I really like the slaughter on most surfaces other than grass or gloop. Currently running a DHR2 on the rear though. Would probably consider the aggressor if i could find it cheap enough in 26. I wouldn't use anything like a semi slick or aggressor off piste though.
Tried a minion ss. It was great when we had the dry weather but just not grippy enough for me in the damp conditions.
Gone back to the DHR ii which has awesome grip and I don't think rolls much slower than the ss.
What does "aggressive" mean in relation to tyres?
WTB Vigilante upfront
WTB Trail Boss 2.25 on the rear
Wagon wheel size, all TCS Tough
Loving it
I hate to disagree with the riding God and tyre gimp Northwind but I'm liking the Slaughter I've just fitted. I needed to drop the pressure a bit yesterday but it worked well on the damp rocky steps on the climb up to Buzzards nest at Glentress. I'm riding everyday this week so I might hate it by Friday though
Butcher grid on front, slaughter grid on back.
Cant beat them really (as long as you dont ride in mud). Super tough,fast rolling,no punctures.
Only downside is theyre quite heavy.
stevenmenmuir - MemberI hate to disagree with the riding God and tyre gimp Northwind
You got that the wrong way round.
Minion SS is just too narrow and square for wide rims.
I've just fitted an SS tonight on a 35mm internal rim and it has a lot more pronounced curve than in that photo. It poured with rain as I was fitting it so it may not be on for long!!
stevenmenmuir - MemberI hate to disagree with the riding God and tyre gimp Northwind but I'm liking the Slaughter I've just fitted. I needed to drop the pressure a bit yesterday but it worked well on the damp rocky steps on the climb up to Buzzards nest at Glentress. I'm riding everyday this week so I might hate it by Friday though
yip, no issues at GT in the damp with the slaughter
Conti F-Trailking2.4 R- X-King 2.2
Quick and grippy, protection carcass and black chili rubber.
I was running trail king apex protection tyres but found the sidewalls too vulnerable for the rocky peak riding I do. Had good results with e13 but wear is too fast.
Currently considering the DHR II WT exo or the Aggressor double down.
Sorry if I'm asking something that was said earlier because I did not read every reply theres a lot of variables but still kinda simple what rim are you running on the back of your bike I personally run 2 sizes on bike with a 35i up front with a 29i on the rear for my own rig presently theres a Minion DHF WT 27.5x2.5 Maxx Grip compound up front with a DHR2 27.5x2.3 and Maxx Terra compound out back but feel the Minion SS in the 27.5x2.3 would be better choice for the overly sun baked Singletrack of So-Cal the dirt in the upper elevations still has a touch of moisture to it so the DHR2 is staying for now.
Some of the rim makers are posting tire size ranges with there rims so you know already what tires you kinda plan to run on your rig gives you a better idea of which width of rim to use front and back and why does everybody still run the same rim front and back hi-perf cars don't do it, hi-perf motorcycles never did it why do bicyclist put the same width rim front and back the tire makers really need to adopt this practice and give us rin sizing the gives us the best tire profile and guidleines of what to expect from a given width of rim they've done the testing you know they know now its time to get them to share what they know with us. Go with the Minion SS
I'm not at all a fan of the SS - just took it off my bike (G160RS 29mm rims). after all, when is it ever totally dry in the UK? I've gone to a shorty WT as I read they roll ok. seems fine so far - at least the back end is not wiggling all over the shop. if the shorty is too chunky then i'd run the DHF front and back. or DHF front DHRII WT back. i'm hopeful that the shorty will do the job.
2.3 DHF and DHR
or
2.3 HR2 and H Dampf
I find tyre pressures make a bigger difference than tread for grip
Northwind & Nobeer,
How does the Trailboss Tough/Fast compare with Supergravity Hans Dampf Trailstar for durability?
Looking for something with tougher sidewalls than the SG HD.
Maxxis dual ply is the sort of durability benchmark I'm looking to match.
Hey mate, these are my two usual rear tyres of choice, so I may be able to offer some useful insight (especially as we ride a lot of the same trails).
The WTB may be slightly stiffer in the carcass, but there's not much in it. I one put a hole in my SG HD (at Stiniog), but have not managed to hole the WTB yet. The HD offers better grip, especially climbing. The Trail Boss has more durable tread.
The Trail Boss is a good enough balance of tread pattern, carcass & price - but never really wows you.
Saying that, if you're subbing one in for that Magic Mary you had on the back you're going to love the rolling speed!
Worth a try if still £30-ish at CRC anyway.
What he says ^
The trail boss works reasonably well on everything, and with the durability added in, It's a good un. I can't comment on how it compares to Hans dampf as I only ever tried those on the rear for a few weeks, and all the side knobs departed (was a pace star compound) and I don't use schwalbe on the rear at all now.
Chakaping, Nobeer,
Thanks, on those recommendations, I'll give it a try.
Probably overcome some of the carcase stiffness and get a bit more grip by running it a bit lower with Procore in.
Which TrailBoss are we talking? Tough Fast, or Tough Hi Grip?
WTB Riddler has served me well so far for the past couple of months
Last year I ran with a Maxxis dhf of the rear at the Ardrock ,and even though im now running a minion ss in the dry I will be swapping that out the week before this years Ard.
I found the DHF quiet fast rolling with the added bonus of not having to worry about killing it on the rocks ,something which I know the Minion ss would struggle with.
Fingers crossed no wind 🙂
Submarined - tough fast.
Jut put my double down minion semi slick on. Will be interesting to see what its like tomorrow hopefully.
Been using a Maxxis Tomahawk Double Down on the rear the last few weeks and very happy with it on my dry dusty rocky trails.
Put a bit of a [url= https://orena45blog.wordpress.com/2017/05/25/review-maxxis-tomahawk-double-down-tyre/ ]review up on blog today[/url] if you fancy a check. 🙂
Barks at dogs.
Had 3 rides now with a RR SG on the back (HD pacestar up front). Wow, what a revelation! Will stick a Magic Mary on the front though next time I'm back at BPW (or anywhere else where I won't be pedalling much)
That tomahawk looks a good compromise orena.
I ran a tomahawk, found the 3c compound fell apart on the rear.
I will probably try some Schwalbe Addix compound tyres when they are available.
Are we assuming from the info available that the bloke in charge of addix was poached from conti and addix is more or less black chilli?
Didn't know that. What are contis like durability wise?
Black chilli compound is generally quite durable, as it doesn't rely purely on softness for grip, its whatever magic nano particles they have in there that does the job.
Most durability issues you see with Conti are from agro riders tearing sidewalls.
I'm certainly interested to see some reviews of the new addix tyres. If they are genuinely a step up from the current compounds i'll definitely be keen to try a burt/ralph combo
Right, to bookend this, I found a Slaughter Grid for 28 quid. At half the price of most offerings from Maxxis, I figured it was worth trying. Gave it a good hammering at Friston today and very impressed, fast, yet seems to really bite when you lean it in, and it goes quite predictably when it lets go.
Will try it at BPW in a few weeks, and probably leave it on until slop starts to be an issue!
My only beef is the now mismatched tyres, ugh.
£28?
Where from?
I was quite taken with Slaughter grids last year and destroyed two in short succession by tearing knobs off and big gash in sidewall. Upped anti with a DH dual ply Slaughter and it was better. Then fashed that, so have gone back to High Roller dual ply and had all winter trouble free until Saturday when I cashed that on Garburn.
Running gashed Slaughter DH with a tube. Enough grip for summer in the Lakes.
[img]
?oh=7ee3818b461002936e856b487752f8aa&oe=599D3A3F[/img]
Does anyone else find that a HighRoller2 has an odd spot that appears to have no grip as you lean into it? Upright or hard leaned it is fine, slight lean = slidey....
I'm back off to an XR4 when these wear out (which at the rate the front soft compound 3c Terra thing is tearing knob edges, won't be long 🙁 )
Some described it to me as "not a mincers* tyre", ie you have it ride it hard and lean right over in the turns to get it to work.
* No offence Matt, I don't like that slidey transition either 😉
