try it?
It's the same colour so what could possibly go wrong?
Nearly took a swig to see if it works on teeth too 😉
How much was it? 😉
Bargain. The same poundshop also does sunglasses that are pretty good for a £1.
yes you have. buy Fenwicks fs10 its the best cleaner does not do damage and is way cheaper than the real pink stuff which melts anodising .the trigger is probably worth a £
It does have a warning on the back, to keep away from children
As if I would go near children 😉
The £1 stuff I picked up is rubbish - waste of a £1, not even sure if it contains any sort of cleaning chemical! Pink water...
Hmmm, might just do a 'one side of my bike was cleaned with & the other side with a well known brand' picture when I get home 😉
I'd try it on something sacrificial first, it could be pink water, or pure caustic, or even out of the same factory as real muc off,
You pays your pound and takes your chance......
Good point khani, neighbours cat springs to mind 😉
[i]How much was it?[/i]
I nearly fell for that.
Put it in a posh shampoo bottle and give it your mrs...
