Fanny-Packs and Upl...
[Closed] Fanny-Packs and Uplift Days
29 Users
Anyone use one in place of a back-pack, pros, cons?
Thinking one for the bare essentials so no drink, but a couple of tubes, multi-tool, levers and co2 pump...
talk to me...
Posted : 21/02/2014 11:24 am
think a saddle bag might be prefable to a bumbag from the 80's.
Posted : 21/02/2014 11:26 am
I'd have thought a seat pack or a plastic bag bungeed under the seat would be better for that little lot. Stop you falling on it.
[s**** mode]
he said fanny!
[/s**** mode]
[edited]
Seriously: maybe just get beerbabe to build you a frame bag to carry the stuff? [url= http://www.beerbabe.co.uk/ourshop/prod_2894264-Front-Triangle-Bag.html ]http://www.beerbabe.co.uk/ourshop/prod_2894264-Front-Triangle-Bag.html[/url] Less likely to hurt yourself falling off onto a sharp bit in a bum bag if it's all in the frame?
Although Camelbacks do provide some back protection in the event of an off.
Posted : 21/02/2014 11:27 am
mind you I suppose they'd be cheap enough in sports dirct or something, what the hell, go for it, it's not a fashion show.
Posted : 21/02/2014 11:29 am
s**** mode]
he said fanny!
[/s**** mode]
any excuse to post this again
IGMC
Posted : 21/02/2014 11:31 am
I think it would be inherently dangerous; a bum bag (sorry I'm not American so I'll use English) sits on your lower back, just above your arse. Not spread out but a raised 'sausage' of gear; tubes, waterproof, tools? In an impact where you land on your back the bum bag could be the first point of contact between you & the ground, focused on a specific point on your spine.
Wear a hydration pack. A lot comfier and would give a small amount of protection to your back.
Or carry nowt. Keep a bottle of water near the van drop and be prepared to walk back to car park if you get a flat/mechanical.
Posted : 21/02/2014 11:36 am
You can't wear a bumbag for an uplift day, they're enduro not downhill! Durr.
I've got a small camelbak I wear for uplifts, it's not cool but I reckon it's worth it- multitool, tube, pump- saves wasting riding time or runs. Wee bit of water in a sqeezy bottle- not essential obviously but you can get dry talking pish on an uplift bus, and if you're on a fast turnaround uplift it turns time wasted in the car park into riding time. Feels like nothing once it's on and a good bag doesn't move around.
Does divide opinion though! Though less so once you help people fix their bike... (though actually, some mates become even more definite that carrying kit is a bad idea, once they know someone else has stuff they can borrow 😉 )
I do have one of those little camelbak things with a pocket and a water bottle holder, which I use for short after-work type rides but I wouldn't use it for harder riding, it's more noticable when riding and moves a lot more.
Posted : 21/02/2014 11:40 am
Not for uplift days specifically but I use one most of the time for shorter (i.e up to 4-hour) rides. They are comfy, the weight is low down and you get less sweaty. I'll usually carry wallet, camera, energy bars, tube and a small toolkit. It's large enough that I can fit in a lightweight jacket and an emergency blanket too.
Posted : 21/02/2014 11:41 am
No.
Posted : 21/02/2014 11:43 am
what about one of those bidon shaped holders if you've got a spare set of bidon holes?
Posted : 21/02/2014 11:44 am
By bidon do you mean bottle cage mounts?
Posted : 21/02/2014 11:46 am
I started to use one after a shoulder injury meant a rucksack was uncomfortable,
risk of falling on sharp tools is the same IMO as a camelback,, just pack it carefully, anyway you are probably going to be hitting the ground, tree, stem,pedal etc so does not really make any greater risk in general.
no sweaty back is nice (in summer) and it is less obtrusive than a hydration pack.
of course you will need to wear goggles and an enduro lid which you may consider a drawback.
Posted : 21/02/2014 11:50 am
I hear you but i hate stuff on the bike when i'm riding. Just don't like it.
That's it you see, maybe i'm getting old but i couldn't give a toss about it being 'fashion'.
Will have armour on with back-protector so don't want backpack on top of armour and i was thinking fanny-pack on outside of armour so no danger in the event of a crash, that's the theory any way.
Posted : 21/02/2014 11:56 am
It's generally quicker to get back to the van/car than fix on a run. Get back and use the track pump/tool kit there.
Posted : 21/02/2014 11:59 am
wot he ^^^ said +1 go back to the van to fix it.
Posted : 21/02/2014 12:17 pm
quicker than pushing down a downhill section? How can that be?
Posted : 21/02/2014 12:36 pm
Don't need to push downhill, bikes tend to go that way on their own if given half a chance. Now finding it still in a usable state after setting it off, that's a challenge.
Posted : 21/02/2014 12:41 pm
It takes about 10mi s to fix a flat if your going ok (guesstimate from plenty of experience) getting a bike to the end of the track isn't that far off and you don't have the hassle of carrying stuff. On UK dh I don't think I got more than 2 or 3 flats on uplift
Posted : 21/02/2014 12:50 pm
Double post
Posted : 21/02/2014 12:51 pm
I dunno, if you flat in a convenient place or you're happy riding on the flat then it can be faster but usually it's not going to be ime. And it's not really saving time to do it at the bottom, you spend most of your time swapping the tube etc so having a track pump just saves a minute or so.
And other mechanicals are even faster, a loose bolt can wreck a run or be fixed in 20 seconds, broken off mech, whatever.
I've lapped people pushing down fort william with mechanicals, so that's basically a run and a half wasted, and riding down is always better than walking down... if you're getting 8 innerleithen runs it's a shame to only ride 7.
I suppose it does depend on your approach to the day, I want to wring every last run out of an uplift but other folks do prefer to take it easy, and fair enough.
Posted : 21/02/2014 1:05 pm
Surely putting the pack at the front would work fine though. Worth a go if you can be arsed.
I've usually got a multitool in a poacket. Only had one flat and managed to limp back and get it changed at the van before the next uplift set off.
Posted : 21/02/2014 1:21 pm
Gaffer tape tube to seatpost, multi tool in one pocket co2 & keys in the other.
Or do what roadies/xc riders do, shove it all in your back pockets.
Posted : 21/02/2014 1:26 pm
I have one for riding motorcycle enduro that has several compartments and is well padded, it works well and is comfortable. Mine's a UFO but Kriega also make some really nice kit.
I occasionally use it on the MTB and really see no problem except that is clearly (^) a major fashion faux pas.
Posted : 21/02/2014 1:41 pm
You'll be wearing an open face helmet with googles next!
I don't really mine wearing a pack and used to wear a back with body armour when in the Alps (water, food plus tools comes in handy when getting away from the resort).
Way back in the day, before packs were common place I used to use one and found it pretty good. It didn't move about too much so wasn't too annoying.
The other option is to just hope that someone else wears on and shove your stuff in theirs!
Posted : 21/02/2014 3:57 pm
I can count the number of times I've had a mechanical that meant I couldn't get back to the car easily while on an uplift day on the fingers of one foot.
You're worrying about nothing, don't embarrass yourself.
Posted : 21/02/2014 4:08 pm
I bought one of these
from [url= http://www.charliethebikemonger.com/king-cage-cargo-cage-tool-pouch-and-waterbottle-cage-3647-p.asp ]Charlie the Bikemonger[/url] holds everything you mentioned and works great.
Posted : 21/02/2014 4:09 pm
t'is what all the cool kidz will be riding this summer...
Posted : 21/02/2014 4:15 pm
Speeder - Member
Agreed.
Puncture? Fine, roll down to the car park (admittedly a ****er when you puncture near the top of Ft.Bill, but i'd still rather head down than carry extra gear and fix it up there)
Gears? Keep on truckin'
Brakes? Gonna be an interesting ride, but you wont have anything useful in your fanny pack.
etc
Posted : 21/02/2014 4:20 pm
In two years of uplifting I've only ever had to walk down once. You can more often than not get a downlift if you are near the top of the track.
Posted : 21/02/2014 4:29 pm
A fanny pack works for skiing so why not for 'uplifts' ? If you rotate the bag to the front on a chair lift it works just fine, I know I've done it.
Alternatively get a frame pack made by Judy at www.beerbabe.co.uk make from recycles inner tubes & brewery malt sacks, just the job.
Posted : 21/02/2014 9:21 pm
My mates took the piss when I took my camelbak to BPW. Until my gear fixed three of their bikes. Reckon I lost at least one run helping/standing around while they used my tools. F-all went wrong with my bike so it worked against me really. That said I can't stand getting dehydrated so having water on tap (I'm here all week, try the veal) is worth it alone.
Posted : 21/02/2014 10:20 pm
I know it's different strokes n all that, but that's not how my riding works. If someone has a problem we'll catch them halfway or at the bottom, everyone I ride with is happy to make their own way down when they have a mechanical. As for drinking, we'll all just take on what we need at the bottom. I don't know of an uplifted track in the UK that would demand a halfway drink
Posted : 21/02/2014 10:27 pm
I can't be arsed rummaging around in the bushes for a bottle of water especially if a bus is pulling up. I also can't stand the number of discarded bottles scattered around uplift centres, for a supposedly environmentally sympathetic user group we're a selfish bunch of pricks.
Posted : 21/02/2014 11:17 pm
You've lost me now. Open van, grab bottle/tools, sit, chat, close up, get back on uplift. No rummaging or discarding involved.
Posted : 22/02/2014 8:04 am
Suggestion up there:
Easy to forget bottles left somewhere near the van drop.
Posted : 22/02/2014 9:03 am
My pack has a back protector in it so obviously I'm going to wear it for uplift days. But even if it didn't, why would I care about having a bit of weight on my back when all my riding is gravity assisted? It's not like you need to fill it completely with water or food or tools or clothes, you're not going into the wilderness!
Posted : 22/02/2014 9:46 am
Either you or I are missing something here...are you suggesting riding to the end with a flat?
Which one do you use scotroutes?
+1 this
consider your kind offer accepted
Posted : 22/02/2014 12:47 pm
Absolutely. Go to a DH race and see how many of the 300+ riders have a huck sack on.
Riding and hitting features as fast as I can is the last place I want to feel extra weight on my back
Posted : 22/02/2014 2:21 pm
Yep, no packs for uplift days. I might stick a water bottle in the cage that's on my bike just to save missing a run to get a drink. I'm hoping for 15+ runs at the Pearce Cycles uplift at Hopton tomorrow. I managed 15 last time on my hardtail, so more should be possible on the enduro bike.
Posted : 22/02/2014 2:29 pm
A lot of european DHers were using them in the Alps last summer. Pretty sensible and useful if you don't need to carry water and spare clothes.
Much better than a 20 - 60 minute walk to the bottom
Posted : 22/02/2014 9:35 pm
Riding in the alps is a bit different though. Being stranded 3 valleys away from base is a major PITA! Riding you slightly wonky bike to the car park at the bottom isn't.
Plus........ Euro-style*......8O
*this is a joke, for the terminally offended
Posted : 22/02/2014 9:58 pm
Dave you are a fanny.
You might not care about fashion, and that's fine, we have a Scouse! But you will get bullied for wearing a bum bag.
On a serious note I would think a bum bag would be more intrusive than a small nearly empty back pack. I personally prefer to ride DH with no bag as like others have said it's not a long way to the car. Just prepare your bike properly and use DH tubes and/or tubeless jizz in them to reduce the chance of punctures. Make sure you take on plenty of fluids before and on lunch, and for one I don't mean Duvel.
Posted : 22/02/2014 10:05 pm
**** me is this really the state of mince that attends UK uplifts nowadays!
Posted : 22/02/2014 11:02 pm
What's this about hiding a bottle in the undergrowth? Surely you just leave a bottle under "your" seat in the van and drink it on the way up?
monkeyfudger - Member
+1
Posted : 23/02/2014 12:34 am
Come on there are more fashion faux pas at trail-centres than a bum-bag! I mean wearing one will just let me blend in.
Besides Andy I'm splitting my gear between you lot - there's a pint in it (to share) for you all afterwards. Don't drink it all at once!
Posted : 23/02/2014 11:12 am
Have a look at the Specialized swat stuff. You might be able to for it to your pitch.
Posted : 23/02/2014 11:28 am
Have u seen the price of it?!
Posted : 23/02/2014 11:33 am
Nope, I don't have the need for such stuff.
Posted : 23/02/2014 4:11 pm
Shit, er I mean awesome recommendation then dude.
Posted : 23/02/2014 6:10 pm
Better solution than a bum bag despite the cost.
If you really want to carry a tube, pump, leavers and tools then just tape them to your frame. You know that I am one for packing load of tools but I genuinely don't see the point for uplift days.
As I said, make your bike less likely to get punctures. If anybody needs to carry tubes and a pump it's Kaye, your more likely to need bandages. 😉
Posted : 23/02/2014 7:02 pm
