EXT Storia v3 shock...
[Closed] EXT Storia v3 shock settings.
4 Users
interested to hear about peoples set-ups and experiences? spring rates / clicks here, knob turns there / rider weight / rider style etc etc.
i have one, its my first ever coil. only one ride in and feels amazing. dont even know how much LSC, HSC, or LSR im running but its a 600lb spring and im 85kg.
Posted : 04/10/2019 8:26 am
Bought it from Mojo Rising? Give them a call
Posted : 04/10/2019 8:56 am
nah im happy with it, just wanted to open a discussion with other users
Posted : 04/10/2019 12:49 pm
Hi Mahalo, I'm 92Kg, riding flats, bike is Evil Offering. Running 575lb spring with 1 turn preload, LSC 6 clicks from open, HSC 7 clicks from open. Rebound is fully closed and it is still a touch fast for my liking so I will need to get it revalved I think. I also have a 550lb spring which gives too much sag so going to swap it for a 600 as I think I'll need the heavier spring during the drier summer months. I found that I had to run a much heavier spring to what was initially recommended. What bike do you have it on and how do you find the rebound speed with the 600 spring?
Posted : 05/10/2019 3:32 pm
Hi neil. It’s a stumpy evo. New bike with the new shock so a lot of change to get to grips with in one go. The 600 spring feels great but like I say I’ve not much experience to compare it too. I also have a 550lb so will try that out soon. It’s also pretty freakin’ grim out there at the moment too so riding is a bit erratic to make good judgement. Hopefully get an uplift day in the diary soon to have a proper play...
Posted : 06/10/2019 12:43 am
I will need to get it revalved I think. I also have a 550lb spring which gives too much sag so going to swap it for a 600 as I think I’ll need the heavier spring during the drier summer months.
Don't think about sag, how is the bottom out performance? It's both a speed and position sensitive bypass valve shock, therefore it's capable of running softer sag. Look into having the bottom out resistance increased - that's the advantage of the Arma over the Storia, it can be adjusted externally.
Posted : 06/10/2019 2:34 am
Hi Raybanwomble it's the rebound speed that is too fast for my liking even when fully closed. Bottom out performance is perfect with the 575 spring. With the 550 spring I had frequent and sometimes violent bottom outs.
Posted : 06/10/2019 9:49 am
Hi Maholo, yes that's the problem I had as conditions were fast and dry when I first got the shock and was still dialing it in when conditions turned slower and muddy!
Posted : 06/10/2019 9:56 am
