Exposure Sirius cha...
[Closed] Exposure Sirius charging
3 Users
Just got an Exposure Sirius MK9. I had it on for an hour or so on one of the higher power programs, and now I'be plugged it in to charge.
The light on the back is solid greem, which according to the docs means it's fully charged - doesn't seem likely that that's the case though? I'm pretty sure the light on the back changed color while it was on.
Also whether the light comes on at all when I plug it in to charge seems to depend on what I was doing with it immediately before. I'm just using the USB cable that came with it - no smart charger
All this makes me wonder if it's charging properly and whether I'm going to get caught out sometime. Anyone else get anything similar with their Sirius?
Posted : 18/09/2021 6:28 pm
Give it a few full cycles and see how it behaves. Batteries can be a bit funny on the first couple of cycles.
Posted : 18/09/2021 7:22 pm
The light turns green at 95% charged and then trickle charges after that. I've certainly put one on charge after brief use and it's gone straight to green.
Did you charge it fully before first use as recommended?
Posted : 18/09/2021 9:19 pm
