Exposure Redeye
[Closed] Exposure Redeye
3 Users
Cable length aside is there a difference between the long and short cable versions?
And can I use the C-C clip to attach a long cable version to my Joystick?
Posted : 13/02/2014 6:46 am
Anybody?
Posted : 13/02/2014 1:30 pm
I can check for you at the weekend if you can wait that long.
Posted : 13/02/2014 1:40 pm
Thanks, that would be great!
Posted : 13/02/2014 1:55 pm
You could use the C-Clip with some strong rubber bands to attach it to the joystick. The rubber band they come with is intended for seatposts so won't hold tight enough on a Joystick.
Have a look at the Exposure TraceR slightly brighter but with the pulse mode it attracts a lot more attention making you harder to miss. One charge will last you all week. Same mount as Redeye.
Posted : 13/02/2014 2:08 pm
Bear in mind the long cable version has an integral bracket to allow it to be mounted to a seatpost.
I can remember if you can remove the light unit from the bracket or not.
Posted : 13/02/2014 2:50 pm
I have the long cable version which just has the seat post mount which you can remove the light from.
Posted : 13/02/2014 2:52 pm
To answer my own question. Yes there is. Light appears to be identical but the cases are different and the long cable won't fit into the C-C clip.
Light's great though!
Posted : 21/02/2014 6:24 pm
