Explain this to me ...
[Closed] Explain this to me then....
10 Users
There's a bike I'm interested in. Specialized Sequoia Elite
It comes with an 11-36 cassette and a 48/32 chainset, running on a 105 rear mech
105 rear mechs, according to Shimano, have a maximum capacity of 37t and a maximum rear sprocket of 32t
How are they getting away with it? Long mech hanger to get round the 36t and several gears you can't use?
Hmmmmmmm....
Posted : 15/08/2016 1:13 pm
It's specialized it's probably a proprietary cassette with less teeth than on the label
Posted : 15/08/2016 1:15 pm
Looks like a long cage to me:
Posted : 15/08/2016 1:16 pm
Specs I gave are for the mech SBC say is fitted - RD5800GS - Numbers are from the Shimano tech website.
Posted : 15/08/2016 1:23 pm
ignore me 😳
Posted : 15/08/2016 1:24 pm
My old 10s 10 rear mech was only supposed to be able to take a 28t but was quite happy running a 36- I think it would only work with a single ring though.
I suspect the recommendations are generally a bit careful and probably assuming certain setups.
Yep. That's it. It's way over capacity.
Posted : 15/08/2016 1:25 pm
IME they're usually correct. In fact more than once I've winced as I've hit low gear on something that's on the edge of its capacity. 🙂
Posted : 15/08/2016 1:27 pm
Just replaced the rear mech on my Giant Revolt. Looking around for the spare was a tad worrying as nothing in the roadie ranges seemed to match the levers and 34T mountainbike cassette the bike came with. Ended up buying a 105, and a 32T XT cassette. Works OK now.
I did wonder if the OEM mech was tweaked to cope or if it didn't cope and that's why it wore out in under 1000 miles.
Posted : 15/08/2016 2:02 pm
Loking at a picture of the Specialized - the mounting for the rear mech looks quite a way down and back (might just be the picture through) - have they, in effect, put their own Goatlink built onto the dropout/gearhanger to allow 36t?
Posted : 15/08/2016 3:51 pm
It'll be fine, it's only 4 more teeth than spec at the rear, and a smaller range than a triple at the front, judicious hanger placement and you'd get away with that.
Most Shimano mechs can be coerced safely at least one cog bigger, sometimes more depending on the specifics of the hanger geometry, and I'm sure Spesh have field tested the combo to death before putting it out on a production bike.
FWIW, my AWOL is running 11-34 with 30-39-50 and a mech rated to 32 teeth and I reckon a 36 would be doable even on that, drop the front range and it's definitely a go-er.
Posted : 15/08/2016 3:57 pm
11s 105 mechs work absolutely fine with 11-36 cassettes, despite what Shimano officially say.
Posted : 15/08/2016 4:14 pm
Shimano recently released 11-46 cassettes for use with the same Shimano mechs whish apparently couldn't cope with bigger than 40t not so long ago
Posted : 15/08/2016 4:19 pm
I take it 11 speed mtb cassettes will fit a 11 speed road hub?
Posted : 15/08/2016 4:28 pm
That was my thinking yes.
Thanks, at least someone else has tried it! 🙂
yes they will. You'll need an 11sp spacer on there though as 11s MTB cassettes fit on a 9/10sp FH body, unlike 11s road which need an 11s FH body.
Posted : 15/08/2016 5:40 pm
Honourable George - Shimano never said that. Slack journalists did, but not Shimano. I've seen the official PP presentation for 11 spd XTR and XT.
They did however initially say that only the 11-40 could be used with a double chainset, then latterly said that 11-42 was fine on a double too.
Just because they only offered XTR in 11-40 doesn't mean that's it's limit.
Posted : 15/08/2016 6:13 pm
Does look like a Goatlink style hanger.
Posted : 15/08/2016 6:15 pm
