What should I do when the sealant in my tyres is life-expired and has stopped sealing? Keep topping it up (and adding weight), or un-mount the tyre and clean out the old stuff before putting new sealant in?
You'd be better popping a bead and cleaning the tyre out. The stuff can ball up and be a big lump sometimes, so it's best to start again.
Sounds like weight is a concern 🙂 best empty it out before thew wheels get too heavy.
Was it dead when you bought it - or just sleeping OP?
Resting, but ever vigilant for holes in my tyre.
Sounds like weight is a concern best empty it out before thew wheels get too heavy.
Well, yes. Drilled Ti bolts all round for me 😛
Thanks - I did wonder whether it would ball up or just coat the inside of the casing. I shall need to get to work on my ghetto inflator - not sure my rims are true enough for the tyre to re-seat without a bit of 'persuasion'.
So what's best method to get the old dried stuff off? Just try to roll it into a ball or are there easier ways?
Usually I just peel, pick or scrape the stuff out. If it's all dried up you may find a [url= http://singletrackmag.com/forum/topic/monsters-in-my-stans-fluid ]Stans Critter[/url] in there.
Didn't have a critter form in 18 months with the previous Fire XC Pros. There wasn't one when I had my back wheel trued in the autumn; doesn't mean there's not one there now...
