Essentials for 11 s...
[Closed] Essentials for 11 speed
6 Users
I've just acquired a new road frame and am in the process of switching the parts over from the old frame. The drivetrain is worn out, so I am thinking of changing to 11 speed at the same time.
What are the essentials? Chain, shifters, cassette, do I need a new rear mech and chainrings?
The wheels will be new, so the hub will be 11 speed compatible.
Thanks
Matt
Posted : 26/11/2016 11:31 am
 aP
What manufacturer?
Posted : 26/11/2016 11:35 am
Pretty much everything on your list, if the old drivetrain is worn better to start from scratch. Decent deals on full groupset can normally be had.
Posted : 26/11/2016 1:27 pm
Shifters, chain, cassette, front mech, rear mech (if Shimano) and possibly new rear wheel or freehub.
Posted : 26/11/2016 2:23 pm
Rear mech add to list, otherwise that's all you actually need if moving from 10sp.
The old crank will work if the ring is good. New rings are always a good idea but not strictly needed if the originals are fine.
As above, buying so many bits together a groupset deal may well be the best value.
Posted : 26/11/2016 2:27 pm
I hadn't thought about getting a full groupset, I'll see what's out there.
Matt
Posted : 26/11/2016 3:50 pm
Fluo shorts
Posted : 26/11/2016 4:28 pm
