Erm. Where does thi...
[Closed] Erm. Where does this bit go?
31 Users
 fabs
So, I have been doing some maintenance. Changing frame/suspension bearings. Fork & dropper post have been removed for servicing etc.
I found this grub screw on the mat:
grub screw
Where did it come from?
bike
(I have already re-fitted the 2 grub screws that help hold the rocker pivot and the chainstay pivot together!)
So will I die?
Posted : 30/06/2019 4:37 pm
Does it hold the cable in place for the dropper? (I’ve never used/seen a dropper so no idea if this is how the cable attaches)
Posted : 30/06/2019 4:43 pm
Does your Gran know you use her bedroom to repair your bike?
Posted : 30/06/2019 4:45 pm
Dropper cable attachment. My latest one has one on each side of the cable.
Posted : 30/06/2019 4:49 pm
 fabs
It's not the dropper cable end bit - I have already fitted that. Also it is slightly smaller than that grub screw.
Posted : 30/06/2019 5:02 pm
It'll be from your grans hearing aid then.
Posted : 30/06/2019 5:04 pm
Ride it and see what bit falls off. As soon as you're released from A&E put the grub screw into that bit.
Posted : 30/06/2019 5:05 pm
Holds one of the fork adjuster knobs in place?
Posted : 30/06/2019 5:20 pm
Do you have a lockout top cap on your fork?
Posted : 30/06/2019 5:24 pm
 tdog
I’m fairly certain it is to do with brake lever... :/
Posted : 30/06/2019 5:27 pm
 PJay
Could be for cable attachment to a Poploc (if you have one) on the fork.
Posted : 30/06/2019 5:29 pm
 fabs
I think my fork has all the bits attached properly. It's a pike - grub screw is in the red rebound knob. Blue Charger knob held on with Allen key.
Posted : 30/06/2019 5:30 pm
Lock on grip?
Posted : 30/06/2019 5:32 pm
 fabs
Just checked the grips. They have all their screws!
Posted : 30/06/2019 5:33 pm
 fabs
Could be brake lever or gear related?
Posted : 30/06/2019 5:35 pm
It's obvious init. But plug battery retaining screw 🤣
Posted : 30/06/2019 6:07 pm
Crank preload?
Posted : 30/06/2019 6:15 pm
Screw that retains the nut for the rear bolt through axle?
Posted : 30/06/2019 6:40 pm
Lols at the gran. Harsh but fair.
Posted : 30/06/2019 7:17 pm
It goes in the Miscellaneous Shite drawer.
Posted : 30/06/2019 7:33 pm
That, my man, goes in the shatners  basoon.
Posted : 30/06/2019 7:40 pm
 fabs
I don't think it is either axle either! The seem to be fine, no obvious missing bits.
Posted : 30/06/2019 9:40 pm
Insert tab A in to Slot B.
Works every time.
Posted : 30/06/2019 9:56 pm
 fabs
Shatners bassoon
Ashamed I had to Google shatners bassoon! 😂
Posted : 30/06/2019 10:02 pm
Pedal pin innit blud.
Additionally, your pedals have fallen off.
Posted : 30/06/2019 10:05 pm
 fabs
It's not a pedal pin. Already checked.
Posted : 30/06/2019 10:11 pm
Brake lever-reach adjustment??
Posted : 30/06/2019 10:23 pm
Maxle tension adjusteriser? Look under the maxle leverdhould be grub dcrew in there I think?
Posted : 30/06/2019 10:49 pm
Could have been stuck in the welts of your shoes
Posted : 30/06/2019 11:27 pm
It’s from your other bike. The one that stopped working for no apparent reason after last time you fettled with it. Either that or it’s from your Grandad’s meccano.
Posted : 01/07/2019 6:28 am
 fabs
I really don't think it is a male screw:
Front maxle doesn't seem to need a grub scew. Rear maxle already has one.
It might well be from my brakes. They are Shimano SlX!?
Posted : 01/07/2019 8:34 am
 fabs
Also could it be from one of the tools?
Posted : 01/07/2019 8:35 am
I think its a humidensfier plate retaining screw. It sits on top of the double locking sprocket.
Posted : 01/07/2019 9:01 am
Reach adjuster from brake lever unit ?
Posted : 01/07/2019 9:07 am
it looks like its for a taper on it so id guess to hold some cable?
Posted : 01/07/2019 10:11 am
Go out for ride. If it's critical you'll soon find out.
Posted : 01/07/2019 10:40 am
Do you have FSA crankset? The bb bearing tensioner is held with a small grub screw.
Posted : 01/07/2019 12:28 pm
We're selling the op short here.
I see the room of a lover...
A passionate fire burns beneath a harsh, stark exterior.
A deep yearning that can only be expressed via the emotional maelstrom that is crochet.
Her name...I'm guessing something to do with the number 12?
Posted : 01/07/2019 12:51 pm
Kona Process?
It does look like one of the locking screws from one of the pivot bearing axles - I can't remember for sure, but are there 2 grub screws on the main pivot (at 90° to each other)?
Posted : 01/07/2019 1:42 pm
 fabs
I will check the main pivot again!
Posted : 01/07/2019 2:14 pm
Just checked mine - nope, just one each :-/
Posted : 01/07/2019 7:47 pm
Have you checked all of your fillings ?
Posted : 01/07/2019 8:43 pm
Has the stairlift mysteriously stopped working?
Posted : 01/07/2019 9:09 pm
 csb
It's fallen out of one of your curtain rail brackets.
Posted : 01/07/2019 9:18 pm
so.....
Posted : 05/07/2019 8:20 am
 fabs
Never found where it came from!
Thanks for all your helpful suggestions!
Bike seems okay, but will take it on a proper tide on Sunday!
Posted : 05/07/2019 9:06 am
nice! one for the spares box!
Posted : 05/07/2019 10:45 am
Battery retaining screw for grandma's rabbit.
Posted : 05/07/2019 11:19 am
