Hi chaps
What settings are owners of Specialized Enduro 650b running?
I've had a session of dialling mine in, but still not quite right.
What settings are others using?
Ricks
What don't you like?
coil, or air?
i have a coil on my 26 Enduro, went with standard suggested settings and it works pretty darn well.
Have you gone through the field tuning guide?
Yep, been through the guide. It feels a little bit harsh, I've back off the high speed rebound and the high speed compression further.
It a DB Inline too
Standard except a couple of extra clicks of hsc and slightly less sag than recommended (I think it should be 18mm and I have it around 16) - livens the bike up a bit
Try adding a volume spacer, that'll mean you can run less HSC and you'll get quicker rebound deep in the travel with the same HSR setting so it won't pack down as much.
Booom! Awesome. I'll give it a go.
