Elixir CR Mag lever...
[Closed] Elixir CR Mag lever rebuild in Edinburgh, or new brakes?
3 Users
One of the levers for the Elixir CR Mags on my Anthem pops out if you look at it funny. I asked the Bike Works about getting the lever rebuilt but they have given up rebuilding Avids and Maguras - more trouble than it's worth, apparently.
So who else in Edinburgh would you recommend for a lever rebuild? Or if the Avid hate is strong this evening what replacement brakes should I be considering?
Posted : 13/10/2014 8:29 pm
They are a doddle to replace the master cylinder. If you have a bleed kit it takes 5 minutes to replace the MC and however longer to bleed them. All you need is here
[url] http://m.jensonusa.com/Avid-Elixir-CR-R-5-Lever-Internals-Kit?utm_source=FRGLAUS&utm_medium=organic&cu=AUD&gclid=CP-on_ffq8ECFYIHvAodCpkArg [/url]
Posted : 14/10/2014 8:43 am
Chris - I have a white lever body, black caliper Elixir CR Mag with carbon lever, works well - it's currently used as a front if that makes any difference, I'd gladly sell you it for £20 posted if it's any use?
Posted : 14/10/2014 9:57 am
I don't have a bleed kit plus the one time I borrowed a friend's to bleed some Juicy Ultimates didn't go too well - but it's hard to tell if that was my fault or the Ultimates as nobody else managed to get them working right either. Plus that's the wrong bleed kit - the CR Mag uses a different kit to the C and CRs. 🙂
Posted : 15/10/2014 12:04 pm
