Elixir 9 brakes, ba...
[Closed] Elixir 9 brakes, bargain, but front only.
12 Users
http://www.on-one.co.uk/i/q/BCAVE9CL/avid_elixir_9_carbon_lever_disc_brake
These seem like a chuffing bargain. Anyone seen any rears going for a similar price?
Posted : 07/11/2013 11:06 pm
Jeez, that is a good price.
Aren't they reversible anyway, so you could just get two fronts and fit a longer hose to the one you want to use on the rear.
You'd just need some Avid hose, some barbs, olives and a bleed kit.
Posted : 07/11/2013 11:14 pm
Yer that's true. For that price you wouldn't mind the messing round. Are these the models from a couple of years ago tho hat had all the reliability issues?
Posted : 07/11/2013 11:17 pm
Dunno for sure, but comparing them to the current range on the Avid website, they look pretty similar.
Posted : 07/11/2013 11:19 pm
I feel an expensive 'money saving' exercise coming on.
Posted : 07/11/2013 11:21 pm
That's usually the way!
Posted : 07/11/2013 11:30 pm
Avid pads £15 to £20; Avid 180mm disc £25 ish
At most that makes the lever, caliper and hose £20.. justified. 😆
Posted : 08/11/2013 8:11 am
Will they work with shimano discs? Got centrelock hubs and discs, so would prefer to just use them
Posted : 08/11/2013 8:51 am
As long as they are 160/180/200mm discs, then they should be OK. Some discs are 183/203mm though and will probably foul the caliper unless you use some extra spacers to push the caliper further out.
Posted : 08/11/2013 10:20 am
Surely Elixir Brakes Bargain is an oxymoron.
There must be some happy long-term Avid hydraulic brake users somewhere, but I'm yet to meet them.
Posted : 08/11/2013 10:23 am
 cp
I've just installed some Elixir 1's on my 'fun' long travel hardtail.
I'm actually very very impressed by them - lots of modulation and feel without the 'anchors on or off' of the XT brakes on other bikes. Not quite the same outright power compared with XT (but not far off), but very very usable power.
Posted : 08/11/2013 10:33 am
I'm a happy long-term user of Avid brakes, pleased to meet you!
CRC are doing Elixir X7 Trail brakes for about £75 per end (not including discs). If you're not bothered about carbon levers...
Posted : 08/11/2013 11:16 am
Ace!
Posted : 08/11/2013 11:26 am
Nope can't see the bargain you're referring to. The only offer I can see has a positive number in the price field. And for Avid breaks (sic) that immediately pushes it out of the "bargain" category.
Posted : 08/11/2013 12:18 pm
Deveron53 - Member
<raises hand>
Me too... Juicy 7s/Ultimates here... trusty 🙂
Posted : 08/11/2013 12:24 pm
 fbk
Long term Elixir user here and, after sram replaced the god awful CR levers with the current design I've not really looked back. A little more fiddly to set up perhaps but strong, well modulated power and very little noise.
At that price it would be rude not to. Now please stop with the PSA frenzy - it's costing me a fortune!
Edit, thanks to the Op btw 🙂
Posted : 08/11/2013 12:49 pm
AlexSimon - Member
Juicy 3's, 7's and Elixir 3's here over many years and very happy with them all.
Posted : 08/11/2013 1:01 pm
AlexSimon - Member
Another happy Avid user. 7 year old juicy 3s.
Bought some elixir 5s recently too.
Posted : 08/11/2013 1:05 pm
Whilst I've had problems with Avids in the past most were caused by poor bleeds / my lack of knowledge rather than crap brakes.
I really like my Elixirs, the key is to get them set up properly.
Now all I need is a retailer to push the Elixir 9 trails out at a cheap price.
Posted : 08/11/2013 10:21 pm
I've had Elixirs for a while, and totally agree, mostly its a bad bleed by users that causes the problems. I've had..... Hmmm.... 4 or 5 sets, all have been great.
I just got some new Elixir Trail 9s, cut the hose and set up today. Easy peqsey, didn't even need to rebleed the, and the power is astounding.
Posted : 08/11/2013 10:27 pm
 fbk
Top PSA. Mine arrived today - full retail kit with all the spares, rotor and fitting kit (post and Is mount). Just need to swap the cable on one to use it on the rear.
Thanks Op - very pleased 🙂
Posted : 12/11/2013 2:39 pm
