Have an itch for an El Mariachi frame: reductions on 2012's increasingly tempting, but concerned about sizing. I'm 6'2" with around a 33" inside leg. Salsa web site suggests I'm in the overlap between L or XL - which way to go if I get the necessary approval?
Cheers.
6'2" with 35" inside leg riding a 2011 20" which seems to be between the L & XL for the newer ones. Reach is spot on for me, which is the most important measurement I think but also I'm leggy so need to watch the seat tube length as have masses of post showing.
I have noticed that I have gone down a size on my 29ers so where I used to ride a 20/21" 26er I now ride a 19/20" 29er.
29ers have slighty higher standover as well like for like.
Try one is best - but sounds like you might be a Large. Oh and if near Berkshire welcome to try mine
I am the same height as you, and to draw comparison with another salsa, the Fargo, I have owned both a large and XL.
I found the large fine, everything up to the max, seatpost near the limit.
The XL in titanium, I find is also fine.
The table above shows that you can be either size. I would eeeer at a large for off road riding.
Hope this helps.
Thanks Charlie - just had a browse round your web-site. Wallet says lucky you're way down south.
